Author Topic: Problem with the new iphone software update!!!  (Read 4605 times)
Offline golfman
  • -Given: 17
« on: June 25, 2010, 04:37:11 pm »
I updated mine and the missus iphone softwares-iOS 4 Software Update
i have the skoda bluetooth kit
and this is what i now get in my highline clocks :sad1:
any ideas guys :confused:
cheers
scott
Vag-com Hex+Can in scotland
I Hate Timewasters...
Offline Sparky Craig
  • Looking To Sell my R32 :(
    • My R32 Page
Re: Problem with the new iphone software update!!!
« Reply #1 on: June 25, 2010, 06:43:46 pm »
I`d try un-pairing the phone and then pair it back again ...
See if that helps...
I take it you have a "B" version Skoda BT unit ...
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #2 on: June 25, 2010, 08:43:26 pm »
I've heard of somoene else with the same problem Scott.
Stu...
Offline golfman
  • -Given: 17
« Reply #3 on: June 25, 2010, 09:53:37 pm »
I have tried several times un-pairing then pairing,ive even unplugged the bluetooth too
This is what i have!!!
Address 77: Telephone        Labels: 5P0-862-335.lbl
Part No SW: 1Z0 035 729     HW: 1Z0 035 729
Component: FSE_2P7x        H24 0020
Revision: 00000001    Serial number: 00000000622861
Coding: 0000322
Shop #: WSC 00787 210 95039
No fault code found.
scott :sad1:
Offline golfman
  • -Given: 17
« Reply #4 on: June 25, 2010, 09:56:05 pm »
Does this mean i might need a newer phone kit stu :sad1:
scott
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #5 on: June 26, 2010, 06:22:51 am »
Either that or revert back to the older iPhone OS Scott.
Stu...
cameluk
« Reply #6 on: June 26, 2010, 10:20:49 am »
3GS ios4 B Skoda bluetooth - same problem, the numbers show correct, but the contact names are rubbish
« Reply #7 on: June 26, 2010, 10:29:11 am »
I shall check mine later but as I don't really use the highline I guess its not too much of a problem.
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #8 on: June 26, 2010, 10:31:27 am »
Yeah a lot of people are reporting the same problem with the Skoda BT.
I know of at least one owner on Briskoda who has the same problem. The only thing I can think is at the contacts are being accessed from the sim. They do get stored weirdly on Sim Cards.
So you could try and copy the contacts from the sim to the phone and then delete them off the sim. But that is risky if you have no way of backing the sim up.
Alternatively you could use something like MobileMe to store contacts etc. That way then you can delete off the sim and not worry about losing them as they a kept by MobileMe.
I don't have a problem but I am using a Fiscon BT kit which leads me to believe it is the Skoda BT and not the Software that is causing the problem.
Offline golfman
  • -Given: 17
« Reply #9 on: June 26, 2010, 11:12:43 am »
Carl all the contacts on the iphones are stored on the phone only!!!
scott
Offline pomme
« Reply #10 on: June 26, 2010, 05:12:31 pm »
I had a similar problem with my alpine unit. I had reset it, pressin off and home button at the same time. Then reconnected it and it worked fine. give it a go mate.
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #11 on: June 26, 2010, 05:45:55 pm »
scott
If you go into settings, mail/contacts/calendars you can see there is an option to import contacts from the sim. Which is why was saying about them being stored on the sim.
Either way i don't think it's an issue with the software as I don't have the same problem with a Fiscon Kit.
cameluk
« Reply #12 on: June 26, 2010, 10:54:01 pm »
Same corrupt names show on the RNS, checked my sim and no numbers stored on it  :chicken:
Only difference between Friday and Saturday was upgrade to IOS4
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #13 on: June 26, 2010, 10:57:29 pm »
scott
Thats just for people that are moving to an iPhone from a lesser model.  :happy2:
#1493
cameluk
« Reply #14 on: June 26, 2010, 11:15:37 pm »
Looks like BMW, Skoda BT, Merc, Audi and Parrot users are having problems with IOS 4
Rumours are that Apple is releasing a new version next week 4.0.1 for the reception problems, and no doubt to patch the jailbreak, maybe they will fix the bluetooth issue as well
