Author Topic: Yet another Air Con woe......  (Read 6264 times)
Offline Boothy
« on: June 30, 2010, 06:27:15 pm »
Well after finally getting my simple but very awkward boost leak sorted my bloody air-cons just packed up! I can't f**king believe it :sad1:
I know there are lots of post in relation to compressors being duff etc but I was hoping somebody might just give me some advice diagnosing what might be the issue before the credit card comes out to play.
 Its been working fine however when they fixed the inter-cooler pipe (that was leaking oil too) they must have steamed or jet washed the back of the radiator and the bottom of the engine bay where the bumper goes underneath as its very clean indeed. That was on Monday and the air-con has been working fine all day Tuesday and first thing this morning however when I've started the car later this eve its just blowing warm, regardless of the setting.
 When I got home I checked that the fans at the front were working and they were both turning however when I turn the air-con on or off now they don't move. Also when its in Econ mode and I turn it off the revs don't drop at all and there's no noticeable change in noise etc. I don't know what that means but remember reading somewhere that it was important with regards to air-con.
 I've checked every fuse in both boxes and they are all okay.
 Just where they have steamed/jet washed there are too sensors. One connects directly onto the rear of what I believe is the compressor (located just below the alternator) and then one on the far-ish left that appears to be connected directly onto one of the metal air-con pipes? I'm wondering if some liquid might have got in there somehow and caused the issue? They are ridiculously hard to get to with my sausage finders so I've sprayed a bit of penetrating fluid on in the hope it will force any moisture out.
Somebody please tell me it sounds like something cheap (but don't lie)!
Boothy.
 :sad1: :sad1: :sad1: :sad1: :sad1: :sad1: :sad1: :sad1: :sad1: :sad1: :sad1: :sad1:
Offline x2dazee
Re: Yet another Air Con woe......
« Reply #1 on: July 02, 2010, 11:18:32 pm »
If theres no noticeable leaks  - regas the Air Con ??
Offline Boothy
« Reply #2 on: July 02, 2010, 11:22:03 pm »
 No noticeable leaks mate. Checked the system for pressure and it seems ok.
Offline Tarmac_Terrorist
« Reply #3 on: July 02, 2010, 11:44:35 pm »
I had exactly the same issue with  a pug 206 GTI i had a few years back. I didn't get the 'click' when turning the system on etc.
I had only had the system regassed 2 months earlier. Dealer suggested some kind of air lock in the system.
Another re-gas and check for leaks with UV light & die in the system and all was well.
As long as it's not the dreaded compressor. Fingers crossed
Offline Boothy
« Reply #4 on: July 03, 2010, 02:46:29 am »
The whole forum should cross there fingers for me mate as I really can't afford a new compressor.  It's booked in to the stealers on Tuesday so hopefully it'll be something simple.
 So come Tuesday, everyone please cross your fingers for me.
Offline Boothy
« Reply #5 on: July 06, 2010, 02:14:54 pm »
Just had a call from the dealers about my air con.
£190 so far for the diagnostic, part and re-gas. Faulty pressure switch or something? Although they can't guarantee that it will defo be the problem it needs fixing before they can highlight another fault, if there is one. Fingers crossed.
Offline Boothy
« Reply #6 on: July 06, 2010, 04:43:13 pm »
Right. The dealers have now charged me £190.00 to tell me my compressor is fooked. Great stuff. There saying the pressure valve was faulty and the only way they could check the compressor was to replace this first. Can anyone on who's in the trade confirm that. It seems a bit ridiculous that they can't check a compressor without the other part and whats the odds on both going faulty at the same time!
Not a happy bunny :sad1: :fighting:
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #7 on: July 06, 2010, 07:13:02 pm »
Why didn't they just ''borrow'' the part to check that it was at fault rarther than replace it first ?.
Offline Boothy
« Reply #8 on: July 06, 2010, 07:20:37 pm »
God only knows mate. The service manager is due to ring me tomorrow but I'm not impressed.
 They said it was leaking gas even though it was blowing fine and has been for ages. I them that the system just doesn't kick in when you press the button and surely the pressure switch wouldn't cause that. I still think its related to the electric. Too much of a coincidence after the jet wash and the odds on  compressor and switch going simultaneously when everything was working ok must be one in a million.
Offline Britishlion
  • -Given: 36
  • I have an eBay business !
« Reply #9 on: July 07, 2010, 06:46:38 pm »
Any news Boothy ???
 :confused: :confused: :confused:
While your on the the best GTI forum, get your wife to peruse my.
http://stores.ebay.co.uk/BRIGHTSPARKS-CONSULTANTS-WEB-STORE
Offline Boothy
« Reply #10 on: July 07, 2010, 06:57:36 pm »
Spoke to the service manager who was a good bloke really. Brought the technician out for me to speak to and he explained there reasons for replacing the pressure sensor. They showed me the old one and pointed out where it was leaking etc too.
 They originally quoted me nearly £750 for the compressor and fitting and all the other dealers were similar. I called back down to see what they'd do and managed to get it for £600. It's still a lot but considering I didn't buy the car from them and don't service it there either I can't grumble.
 Although I didn't think that at first so I rang VW directly to see what they would do. And guess what they did? SQUAT!
 I can get the part cheaper but no where will guarantee the part etc unless I more or less replace the entire system so I opted for the dealers with a 2 year warranty on it.
Absolutely gutted though.
« Last Edit: July 07, 2010, 07:00:27 pm by Boothy »
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #11 on: July 07, 2010, 08:18:09 pm »
Looking at it now you have got the price down to £600 thats basically you Paying £40 for them to diagnose the fault.
Feel for you mate. £600 is a lot to pay out for one part. But just think though when it's boiling hot outside you will be able to keep cool again :happy2:
Offline Boothy
« Reply #12 on: July 07, 2010, 08:36:29 pm »
I know mate. I suffer from hayfever really badly and having the Windows down on a hot day makes it a hundred times worse. It makes the aircon not only a luxury but a necessity so when the sun comes out to play again it'll be £600 of utter bliss!  :smiley: :laugh:
Offline Drapoon
« Reply #13 on: July 09, 2010, 11:32:04 am »
Feel yopur pain
my car was 9 days out of warranty & the air con packed up.
I had a suspect fooked compressor, turned out to be the pressure switch which was fitted last week & had no problems since.
Dealer told me that when they went to re-gas the car they could hear the pressure switch leaking from a mile away yet when I had it re-gassed eleswhere a week earlier both I and the mechanic didn't hear a thing!
I managed to wangle 100% parts 50% contribution to labour after a lot of ballache & visits to various dealers. I just hope that's the end of it & the compressor doesn't go next!
Offline Boothy
« Reply #14 on: July 09, 2010, 11:35:30 am »
VW told me that they would consider a recall on the crap compressor if enough people complained. Maybe a should start a petition!
