Author Topic: Air con blowing hot air  (Read 3534 times)
Offline funkythumbs42
« on: July 02, 2010, 09:34:27 pm »
Read a lot of horror stories about aircon compressors failing on mkv gti's
my 55 plate gti will only blow hot air when climate control is on, if i press the "econ" button the air blasted out is cooler but still not ice cold.
When i turn the aircon on i get a clicking noise.
Does this sound like a faulty compressor?
Offline Toast
Re: Air con blowing hot air
« Reply #1 on: July 02, 2010, 09:54:20 pm »
Could be your pressure switch mate as thats whats wrong with mine on my 07 ed30 think its £42 from the dealer :happy2:
« Reply #2 on: July 02, 2010, 10:25:00 pm »
it blows red hot air no problem, put it to low and it just blows out room temperature air, hit econ and it cools a little but not much
if it was the compressor would hot air still work?
Offline Toast
« Reply #3 on: July 02, 2010, 10:28:42 pm »
Not sure mate but mines is doing the exact same thing got my friend to re-charge the gas and you could here it leaking from the pressure switch in the engine bay when he started filling it up!
Offline golfgti06
« Reply #4 on: July 02, 2010, 10:29:40 pm »
i have the same problem on my 06 gti i was told it was the compressor and vw dealer want £1200 to fix it. :driver:
« Reply #5 on: July 02, 2010, 10:34:21 pm »
F*ck that il just open the window
these little niggles really spoil the enjoyment of the car
Offline mb
  • -Receive: 29
« Reply #6 on: July 02, 2010, 10:35:32 pm »
When you press the econ button it switches the aircon off.
When my compressor went, it blew hot air at whatever temp/setting I had it set to.
« Reply #7 on: July 02, 2010, 10:36:54 pm »
the higher i put the setting the hotter the air get till its toasty warm, anything below around 22 and it doesnt get any colder as i say unless i press "econ" and then it gets a little cooler, strange one
Offline golfgti06
« Reply #8 on: July 04, 2010, 12:07:20 pm »
yeh she asked if i wanted to book the car in for it to be fixed i told her to get f*cked i go asda for £10 cool bx and cut eyes out and drive round with that on my head and said it was the compressor not a engine i wanted,she even said that was with discount on the labour from 85 an hour to 75 and hour. they must have your man bates from microsoft working for them lol
