Author Topic: edition 30 flat spot  (Read 2341 times)
Offline flyboy1976
« on: July 03, 2010, 04:57:26 pm »
hi all, still cant resolve why im finding that the car holds back under WOT in the higher gears. mods includes S3 intercooler,forge twintercooler, bkr7eIX plugs, hpfp,rs4 valve,revo 2+ 6/4/6  milltek exhaust/intake etc.no fault codes in vcds and all coil packs are new, revision D diverter valve and N75 is new also!!!! im at a loss, does anyone have any clues, typically happens at 5k rpm...its happens without the traction control, it does feel like the timing pulls back tbh. Cheers in advance if anyone can help
Offline Reesy
Re: edition 30 flat spot
« Reply #1 on: July 03, 2010, 05:20:17 pm »
Hi mate
why are you Revo settings so low, I have fiddled with my settings quite a bit and have the same mods apart from the twin intercooler. I have found that the greatest settings for sheer accelaration & overall oem smoothness, has been B9 T7 F9 and will pull in each gear up to 7.5k. These settings have no flat spots what so ever
all the best
Reesy
Offline Reesy
« Reply #2 on: July 03, 2010, 05:23:30 pm »
I also every 5k run STP fuel injector cleaner through the tank, just to ensure the injectors are working as they should
Saint Steve
« Reply #3 on: July 03, 2010, 05:42:05 pm »
Hi mate
all the best
Reesy
Was gonna say yours are set Rather High aernt they!.
I havent got stage 2+ but im sure they shouldnt be set as high as that fella
Offline flyboy1976
« Reply #4 on: July 03, 2010, 06:10:47 pm »
FUEL 9???? Thats the leanest value as the fuel values work in reverse!
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #5 on: July 03, 2010, 10:46:06 pm »
Exactly.
A car like yours will normally run something like B9T6F6 but logging it will be the best way to know what settings are optimal / safe.
Has it been logged to see if the timing is pulling back?
Offline flyboy1976
« Reply #6 on: July 03, 2010, 11:54:49 pm »
Cheers steve,
its set to 8 6 5 and still does it, im running on shell super and always have done, it seems to happen in 5th between 5k prm and clears at 6k so just in that 1000rpm bracket all other gears are brutal with the revo software, huge grin factor! i did the RS4 valve but its not cleared the issue as i thought it might, dont have a lead to data log on vcds but would be great to see whats happening, its def not a misfire or a stutter just a slight flat area within the rpm range and only in 5th gear but of course only tried this on a private road  :innocent:
Offline s3dubbin
« Reply #7 on: July 04, 2010, 09:30:51 am »
Very interested in this topic i have the exact same problem with the exact same spec without the cooler? Flat spot at 5k rpm every time? Went stage2+ at inters running 8/4/5 on the lower setting until i can afford £1k for a clutch and then it will get turned up 9/5/5 as they advised. Stevie.
Offline s3dubbin
« Reply #8 on: July 04, 2010, 07:02:25 pm »
Come on guys n gals lets keep this one going? Just my luck to be landed with this!!!....
Offline chedone
« Reply #9 on: April 02, 2013, 02:37:36 pm »
same prob im running 9 7 6 you dont feel the flat spot so much if you drop the boost to 7 but its not as good.
flat around 5200 to 5700 then picks back up weird didnt make any diff with the rs4 valve
Ched
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #10 on: April 02, 2013, 04:47:14 pm »
Have you changed your clutch...?
Don't think I've noticed any flat spots at stage2+ with B9 T5 F7... it just flies! :)
Diesel Daily Hack.
Offline bobsey
« Reply #11 on: April 02, 2013, 11:55:45 pm »
It is the revo files at fault, change your fueling to 9 and it will disappear, if your running the software from 2010.
If the map has been uploaded to your car recently that wont work, because of the latest software update. Im in the same boat atm and revo say there is no issue, which there is but only affects a few cars.
Offline chedone
« Reply #12 on: April 03, 2013, 10:54:31 am »
ok so your saying lean it out ??
yeah i had the latest software think it was November i had it installed
mine is a gti with k04 and stage 3 .. never had a prob with stage 2+ on the k03 use to pull all the way through as soon as i went stage 3 it got this flat spot
ok so ill try the fuelling on 9 tonight
cheers mate
Ched
Offline chedone
« Reply #13 on: April 03, 2013, 10:56:00 am »
sorry and yes done the clutch
Ched
Offline robern2
« Reply #14 on: April 03, 2013, 01:34:10 pm »
My stage2+ ed30 car has always suffered the same beyond boost setting 6 albeit less pronounced since the RS4 valve (currently b8t6f6) - no errors found logging mine.
Interesting to see if anyone else has noticed if leaning out fuel improves matters. tbh as I can drive around it e.g by using higher gears it's not (in my opinion) worth the likely reduction I'd need to make to timing.
