Author Topic: Puncture with a BBK  (Read 1946 times)
Offline xxx_mojo_xxx
  • MUBster DUBster
Puncture with a BBK
« on: July 05, 2010, 12:16:26 am »
What would you do if you got a puncture and you had a BBK fitted on the front?
Presumably, the standard space saver wheel would not fit?
Re: Puncture with a BBK
« Reply #1 on: July 05, 2010, 12:19:17 am »
use the rear wheel for the puncture and put the space saver on the rear.  :wink:
  • MUBster DUBster
« Reply #2 on: July 05, 2010, 12:23:35 am »
Thanks TC.
Wots ur preference...should get a spare Monza II and carry it in place of the space saver...  not too keen on the adding extra weight though.
Also, I'm assuming it would fit in the back.
« Reply #3 on: July 05, 2010, 09:03:24 am »
I carry the space saver its fine to get you to the garage.  :happy2:
Offline tony_danza
  • -Receive: 112
« Reply #4 on: July 05, 2010, 09:04:29 am »
I agree on just swapping a rear, but a full sized alloy probably weighs less than the space saver, you'll need the R32 boot inserts though to lift the false floor.
Buy a cheapo 17" Monza, job done.
Sideways yo!
  • MUBster DUBster
« Reply #5 on: July 05, 2010, 11:00:02 am »
Can you explain about what the false floor and R32 insert thingy is all about...?  Thanks, Mo
Offline tony_danza
  • -Receive: 112
« Reply #6 on: July 05, 2010, 11:36:27 am »
I haven't got a pic, but basically the R32 has 2 polystyrene inserts that sit on the boot floor either side of the wheel to raise the false floor/carpetted cardboard thing up high enough to clear the spare.
Make sense?
Sideways yo!
« Reply #7 on: July 05, 2010, 11:37:35 am »
The R32 doesn't have a full size spare its just it has an elevated boot floor thanks to the 4WD.
« Reply #8 on: July 05, 2010, 11:43:03 am »
You can run a full size spare if you have the inserts.
Also, the R32 has a much more rigid boot carpet IIRC. without this, its a bit of a mess using the floppy boot carpet from the GTIs
  • MUBster DUBster
« Reply #9 on: July 05, 2010, 11:51:44 am »
Anyone got photos from an R32 so I can visualise this...
