Author Topic: Help ESP light stays on.  (Read 5064 times)
Offline cossy
  • -Given: 17
  • 57 REG ED30 5325 MILES!
« on: July 05, 2010, 10:01:10 am »
Not sure which section to post on cause it relates to my 2006 VW Jetta 1.9TDI. Coming to work this morning the ESP light remained on.
Any ideas? it was okay last time I used the car.
Will check the ABS fuses lunch time at work but if they are okay Im stumped!
Any help much appreciated.
Cheers :sad1:
Offline Bogwoppit
Re: Help ESP light stays on.
« Reply #1 on: July 05, 2010, 01:15:08 pm »
It could be the dreaded Teves MK60 ESP problem, I suggest you get the fault code read using VAGCOM ect.
For more info read this : http://www.telegraph.co.uk/motoring/caradvice/honestjohn/7844231/Beware-cars-fitted-with-Teves-Mk60-ABSESP-systems-Honest-John.html
Offline cossy
  • -Given: 17
« Reply #2 on: July 05, 2010, 01:39:49 pm »
***t never heard of it before, how do I check if the car has this module? thanks.
Is there any harm driving around with this on? Not looking to sell it any time soon.
« Reply #3 on: July 05, 2010, 01:43:28 pm »
You have that module!   :scared:
Get the car scanned as it may just be a faulty abs sensor.
Offline cossy
  • -Given: 17
« Reply #4 on: July 05, 2010, 01:49:39 pm »
would it be worth buying a scanner(and which one) to scan this myself Cheap one obviously.
« Reply #5 on: July 05, 2010, 01:53:58 pm »
For a few beer tokens I'm sure someone from here will scan it for you.
http://www.mk5golfgti.co.uk/forum/index.php/topic,120.msg1061.html#msg1061
Offline cossy
  • -Given: 17
« Reply #6 on: July 05, 2010, 02:13:07 pm »
were is the unit located & found this option if its the module. Any one used?
http://www.ecutesting.com/vw_golf_touran_abs_pump_module.html
« Reply #7 on: July 05, 2010, 02:24:52 pm »
Don't jump ahead of yourself, first get the car scanned then move on from there.   :smiley:
Offline cossy
  • -Given: 17
« Reply #8 on: July 05, 2010, 02:33:41 pm »
always think the worse!!
Was going to get my own scanner as VW want £80.
Would this one be okay and could I reset/switch off the warning light with it?
http://www.talktomycar.co.uk/products/advcode/MaxScanVAG405.htm
Offline 182_blue
  • -Receive: 54
« Reply #9 on: July 05, 2010, 03:13:35 pm »
Please tell me there not still using these ABS units ?!!, Cossy where are you located ?
Offline cossy
  • -Given: 17
« Reply #10 on: July 05, 2010, 03:19:35 pm »
Norfolk/Suffolk border
Offline 182_blue
  • -Receive: 54
« Reply #11 on: July 05, 2010, 03:24:36 pm »
Ahh, ok too far for me then
Offline cossy
  • -Given: 17
« Reply #12 on: July 05, 2010, 03:26:40 pm »
do you have VAG com?
Should of kept the 172CUP!
Offline cossy
  • -Given: 17
« Reply #13 on: July 14, 2010, 10:15:37 am »
Its the dreaded ESP system, quoted between £1200 & £1500 beware all that use this system!!
On the plus side and after a bit of negotiation (Press Clippings etc etc) VW have agreed to pay for the part £700 plus vat and 50% of the labour to fit it.
Final bill to be £176.00,. Result I think especially as out of warranty by 9 months and I serviced it myself albeit using VW parts and kept the receipt.
Well happy could of been a lot worse.
Offline ukdub
« Reply #14 on: July 14, 2010, 11:19:31 am »
To anybody else that is out of warranty with this part failing, below is a useful link.  :happy2:
« Last Edit: July 14, 2010, 11:21:25 am by ukdub »
Laser Blue with K04 power, APR hardware controlled by REVO 2+ software
Chassis by KW V3's, Whiteline and a hint of PRO race 1.2's
Brakes by Brembo 4 pots
