Author Topic: Milltek 3" Turbo Back Exhaust System Review  (Read 33159 times)
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« on: July 05, 2010, 06:30:34 pm »
Background
On my previous car (Mk5 Edition 30) I ran a Milltek system for well over 50k miles.  During this time I had some modifications done to the system by Milltek that really made the system what I wanted it to be (basically something in-between a res and non res system with a shallower / less visible rear silencer). However during the ownership I did experience a couple of faults with the system. The first was down to incorrect installation by the original supplying Milltek dealer which caused the flexi section to split. The second issue was the plating on the tail-pipes cracking / splitting. Both of these issues where resolved quickly by Milltek under the warranty.
These issues did give me some concerns and when the time came to choose the new system for my Mk6 GTI I did not immediately consider a Milltek one. During my research on the available systems I was given the opportunity by Revo to try a Blue Flame one that featured their branding, at a similar time I was also contacted by Milltek, but due to timescales the opportunity to get the blue flame system on the car came first.
While this system ticked all the boxes on paper in terms of spec (Stainless Steel Construction, 3” diameter pipework and 100 cell CAT) the reality for me personally was it didn’t work. Mainly the “issues” where related to needs for a system, the sound levels from cold start and between 3-4k are excessively “boomy” and “droney”, and that at higher motorway speeds the system was very intrusive. I also felt the construction of the system showed why it was cheaper, benefits like not having a large rear silencer where lost because of the use of cheaper U clamps that where visible when following the car on the road or when stood a few meters behind it. The system also seamed to have a mind of it’s own in that some days it could be relatively quiet and others it was far louder.
On the positive side of things the system did make the car feel far more responsive and most certainly gave good performance increases.
After running the blue flame for a couple of weeks (and a ring trip), while it had a lot of good points, it was clear in my own mind it wasn’t the right system for me.
Shortly after this I was contacted by Milltek to discuss the option to use my car to develop something new for the Mk6. From the outset of the discussions I had with Charlie at Milltek I was impressed and felt reassured by the fact they acknowledged that going back over the last 12 months or so there had been some quality issues, he took time to describe the various steps Milltek had taken to address the quality issues that some customers had experienced. This included substantial investment in new equipment and technology to allow them to test the metal being used in the production of the exhausts rather than being in the hands of various suppliers.
So off the back of this discussion a new Mk6 system has been created. The remit agreed between Milltek and I was to deliver something a bit more performance orientated than their existing Mk6 system (which is designed to meet the various levels of regulatory requirements in the different markets Milltek have dealers in) and to also produce a new system that looks and sounds the part without going OTT.
So now you know what/why/how I have come to having this system, on with the review.
Why
Simple answers is, a turbo back exhaust system is widely know to improve performance (more so when used with a stage 2 remap), but also improves the aesthetics and sound output of the car.
For me all three of the aspects are as equally important when choosing an exhaust system. The Mk6 design/layout of the “wheel barrow” handles that are set into a diffuser means the tips need to be a good size with an angled slash cut to fall into line with the shape of the diffuser. This design also means the central rear silencer that is found one the OEM system is very visible so again an exhaust system that addresses this was also important to me.
So here is the end result of Milltek’s development efforts: -
VIDEO TO FOLLOW, CURRENTLY BEING EDITED  :party:
So the system is made up of: -
Large-bore Downpipe and 100 cell Hi-flow Sports Cat
Front Connecting Pipe
Centre Silencer Assembly
Twin Rear Silencer Assembly
GT100 Tip Assembly
All made up in 3.00" / 76.20mm diameter pipework
Sourcing
Pricing TBC
Available to order from Milltek Dealers. List of dealers can be found here - http://www.millteksport.co.uk/stockists.cfm
Info on the system can be found here - http://www.millteksport.co.uk/exhaust.products.cfm?variantid=308 (Product 7)
Fitting
Not massively difficult, this system once can be installed in under 2 hours by a competent garage.
Most Milltek dealers will offer a fitting service.
Other versions
Blue Flame
APR RSC
Akrapovic (Coming soon)
MV Sport
Or Custom Built Systems
Plus Points
Massively improved aesthetics, no large centre silencers or visiable U clamps to be seen.
Good sound levels and minimal motorway drone which only comes in well above the national speed limit. 3-6k RPM sound level has a deep tone with a the DSG burp on gear change sound is nicely enhanced by the system.
True 3” turbo back system with a properly sized 100 cell CAT, delivering improved performance, better throttle response and more induction noise.  :evilgrin:
Minus Points
As it uses a 100 cell CAT a stage 2 remap will be required or the EPC light will be lite up on the dashboard.
Summary
If your looking a system that gives the loudest possible noise, then this isn't the one for you. However I really believe Milltek has massively stepped up their game with this system and have more than exceeded all of the expectations I had for appearance, sound quality/level and performance increases. The quality of workmanship and the materials appears to me to be the best I have seen on an aftermarket system of this level.
I have now put over 1500 miles on the system since it was installed and it has shown no sign of any issues or fitment problems. The car has adapted well and despite some more work being needed on the stage 2 software I am running the performance has remained strong and the fuel economy is unaffected.
I have been very fortunate to be able to be involved in the development of this system, but given what I now know of the system I would 100% buy it if I still in the market to do so  :happy2:
Offline NB07
Re: Milltek 3" Turbo Back Exhaust System Review
« Reply #1 on: July 05, 2010, 07:56:53 pm »
excellent review steve. im sure many people have bee waiting patiently for this but its great that after a good few miles you can confidently say its a good choice.  :happy2:
 i do find the blueflame on the MK5 can be noisy but ive enjoyed it mostly, the main thing is really performance and its good that milltek are recognising this for the MK6. im personally considering another motor now mine is out of warranty and am very interested in what milltek could offer if i get a MK6 in the future.  :smiley:
  • -Receive: 291
« Reply #2 on: July 05, 2010, 09:24:38 pm »
 :congrats:
Nicely done. And the car looks the dog's bollocks!
Offline alex_chung
« Reply #3 on: July 05, 2010, 09:52:16 pm »
Nice review. Looks awesome!!
Alex
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #4 on: July 06, 2010, 12:28:17 am »
Looks great & those L.E.D rear light really change the back of the mk6,the orginals did nothing at all for it. :happy2:  :congrats:
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #5 on: July 06, 2010, 07:43:32 am »
for a moment there I though RR had hacked your forum account  :signLOL:
thorough, well presented and great pics writeup for the section thanks Steve  :happy2:
Its the first exhaust for the mk6 I like , the std system is pretty poor aesthetically
as usual I have some questions  :laugh:
Is there a choice of tips/styles that can be applied if I was a prospective buyer?
In terms of longevity , any differences using a 100cell cat  vs the OE one?
Milltek always have dyno comparisons, was that done on your car or you waiting for it to soot up?
Any sound level comparisons in db with original vs new ?
 :drinking:
Red ED35 5dr DSG
BLOG | BUILD
« Reply #6 on: July 06, 2010, 09:53:13 am »
that does look like a quality bit of kit.
The two small back boxes on the back look brilliant. Intricate and solid!
looking forward to hearing the video.
Offline GTIforpassion
« Reply #7 on: July 22, 2010, 08:37:52 pm »
Wonderful exhaust system, Milltek is really the best (as SuperSprint !!).
Offline Neilgti
« Reply #8 on: August 21, 2010, 09:17:11 am »
Good shout on the new Milltek Mr. P  :happy2:
Loving mine great sound and throttle response, went for the stealth look,
Needs a wash i know  :smiley:
« Last Edit: October 06, 2011, 07:48:55 pm by Neilgti »
MK5 GTi
MK5 R32
MK6 Gti, all gone but not forgotten
Now loving the 7R
« Reply #9 on: August 29, 2010, 10:39:20 am »
Ooooh! :drool: :drool: :notworthy: - Am loving that red Mk6 arse. Satin black ceramic tips?
Offline Arthuar
« Reply #10 on: April 08, 2011, 08:20:18 pm »
any idea of fuel consumption now?
Thanks for the useful review  :happy2:
Offline Arthuar
« Reply #11 on: April 17, 2011, 08:19:08 am »
UP  :happy2:
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #12 on: April 17, 2011, 08:25:23 am »
When combined with the stage 2 remap I haven't seen much of a change TBH. :happy2:
Offline Arthuar
« Reply #13 on: April 17, 2011, 08:48:00 am »
wow, good result with that performance level.
Thanks Steve.
Offline Andygtiiii
« Reply #14 on: July 31, 2013, 07:22:41 pm »
Can't fault milltek they fit better than the standard exhaust
