Author Topic: I have the following Fault Code's - Help Required Please. No Power !  (Read 2824 times)
Offline johnford60
  • MK5 GTI DSG 265BHP
    • JR Tuning
I have had a fault for a couple of weeks now with intermittent power loss and have another thread open on here about it. t has got worse these last coiuple of days. On the way to my friends how to run VCDS on it i lost all power, I think i lost all turbo power!.
 Faults Found:
000564 - Boost Pressure Regulation: Limit Exceeded (Overboost Condition)
               P0234 - 001 - Upper Limit Exceeded
             Freeze Frame:
                    Fault Status: 01100001
                    Fault Priority: 0
                    Fault Frequency: 20
                    Mileage: 145435 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:49:20
             Freeze Frame:
                    RPM: 6653 /min
                    Load: 81.5 %
                    Speed: 130.0 km/h
                    Temperature: 87.0°C
                    Temperature: 42.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 13.970 V
012403 - Fuel Pump Circuit: Electrical Malfunction
               P3073 - 004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 0
                    Fault Frequency: 2
                    Mileage: 147682 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:09:09
             Freeze Frame:
                    RPM: 903 /min
                    Load: 25.5 %
                    Speed: 6.0 km/h
                    Temperature: 47.0°C
                    Temperature: 37.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 14.097 V
Hope someone can help me out?
John
John
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: I have the following Fault Code's - Help Required Please. No Power !
« Reply #1 on: July 06, 2010, 08:34:23 pm »
It looks like the overboost happend a while before the fuel pump.
Have you 'messed around' with the fuel pump at all?
If you clear the codes do they return?  Try checking the fuses for it.
Stu...
Offline johnford60
    • JR Tuning
« Reply #2 on: July 06, 2010, 08:35:41 pm »
Not touched fuel pump, and cleared codes,and still drove badly!
John
Offline S2 Ant
  • -Receive: 21
« Reply #3 on: July 06, 2010, 08:50:07 pm »
I'm not sure but a fault indicating excessive boost would make me want to check for a boost leak perhaps?
I'm still learning my way on these cars.
Ant
Offline nc35
  • -Given: 40
« Reply #4 on: July 06, 2010, 09:28:10 pm »
First thing I thought was a faulty DV.
Not sure about the fuel pressure. Could be a one off
No Golf anymore.
Enjoyed the last five years of ownership of Mk5 & 6 GTIs.
Plus an excellent forum for knowledge and new ways to deplete the bank account.
Thank You Everyone.
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #5 on: July 06, 2010, 11:29:04 pm »
http://wiki.ross-tech.com/wiki/index.php/16618/P0234/000564
for the first one.
N75 can be replaced , although it happened at close to rev limit so may just be a one off
as others said reset and try to recreate.
BUT if the car feels poor then maybe its the primary issue
a good logging session is required really to work out whats going on  :happy2:
Red ED35 5dr DSG
BLOG | BUILD
