Author Topic: ESP & tyre pressure sensor warning light coming on?  (Read 6975 times)
Offline Pullafacial
« on: July 07, 2010, 09:05:21 am »
3 or 4 times in the last couple of weeks my ESP and tyre pressure warning lights have decided to come on mid journey and stay on until ignition is switched off and on again.
Anyone seen this before or got any ideas as to what it could be?
Offline S2 Ant
  • -Receive: 21
Re: ESP & tyre pressure sensor warning light coming on?
« Reply #1 on: July 07, 2010, 11:50:06 am »
Have you checked the tyre pressures?
Ant
Offline Pullafacial
« Reply #2 on: July 07, 2010, 01:03:09 pm »
Hi ant - not recently, could a low pressure on a tyre cause ESP light to come on?
When this happens, the buttons near the ashtray won't turn off the lights.
Chris
« Reply #3 on: August 03, 2010, 09:15:56 pm »
Dont the tyre pressure run off the ABS Sensors, thought they detect a difference in rolling radius. Maybe its an ABS sensor problem
Offline mk2mexico
« Reply #4 on: August 06, 2010, 04:20:31 pm »
Tyre psi is linked to the abs set your psi to 32 and reset tpm
Offline edd666999
  • -Receive: 89
« Reply #5 on: August 06, 2010, 04:54:45 pm »
Just checking, you need to hold that button down for a while before it turns the warning off?
Offline S2 Ant
  • -Receive: 21
« Reply #6 on: August 06, 2010, 04:56:12 pm »
Pressing and holding i believe resets the value that would trigger the alarm again
Ant
