Author Topic: Mapped the s3! Not that blown away?.......  (Read 13790 times)
Offline MitchGTI
« on: July 07, 2010, 02:10:03 pm »
I got the S3 remapped on monday (reset my blufin from my gti!) and im not that impressed? It doesnt feel like a 300bhp car? I used to have a stage 2 ko3 gti and that was awsome! But this just isnt that exiting!! Whats going on? Also im sure there is a problem with the DV? It makes a sorta dragged out long dump when you let off the throttle not a sharp release like i used to get on the gti wich had the uprated G version?! And it whistles like mad??
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
Re: Mapped the s3! Not that blown away?.......
« Reply #1 on: July 07, 2010, 02:22:30 pm »
Very easy to check the DV as it's located on the front on the engine.
I would also get someone with VCDS to log the car to check for any other issues :happy2:
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #2 on: July 07, 2010, 02:45:46 pm »
agree with Steve  :happy2: log to check boost levels.
would also consider that you have the wrong map or the std map which means you dont get any extra hp  :surprised:
whistling with increased boost is normal to some extent, but could also be loose hoses etc
my comedy answer was going to be
Quote
its a posh golf , they come dull as standard  :P
:signLOL:
« Last Edit: July 07, 2010, 02:47:18 pm by john_o »
Red ED35 5dr DSG
BLOG | BUILD
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #3 on: July 07, 2010, 02:54:28 pm »
You should see a similar real world performance to a GTi Ed30 mapped however while the ED30 is still leaving it's rubber on the road behind you, you'll be away on your toes.  :evilgrin:
Stu...
« Reply #4 on: July 07, 2010, 02:57:33 pm »
Hardly away on its toes with the additional weight of a propshaft and Haldex  :P
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #5 on: July 07, 2010, 03:06:28 pm »
^^^ says the man with two more cylinders and 1.2 litres of displacement  :signLOL:
« Reply #6 on: July 07, 2010, 03:10:38 pm »
It should do mate, when I had my Revo Stage 1 loaded the difference was night and day! As everyone has said get some logging done  :happy2:
Offline 182_blue
  • -Receive: 54
« Reply #7 on: July 07, 2010, 03:12:20 pm »
As mentioned above, check with Superchips to see if you got the right map  :happy2:
Offline Janner_Sy
  • -Receive: 113
« Reply #8 on: July 07, 2010, 03:15:16 pm »
also dont forget in an Ed30 your going from 230Hp to 280-300Hp, in the S3 your going from 260hp to 280-300Hp.  big difference, and to be fair your prob not making 300Hp anyway
Offline 182_blue
  • -Receive: 54
« Reply #9 on: July 07, 2010, 03:24:28 pm »
This is very true + Im guessing the S3 is heavier ?, i just got my R remapped and i can tell its been done but it doesnt blow your nuts of like the Golf did, then again the R felt quicker than the standard ED30 did so its all relative
« Last Edit: July 07, 2010, 03:28:33 pm by 182_blue »
Offline Sunglasses Ron
« Reply #10 on: July 07, 2010, 04:06:12 pm »
What software you gone with this time Shaun?
« Reply #11 on: July 07, 2010, 04:41:34 pm »
FTMFW  :evilgrin:
« Reply #12 on: July 07, 2010, 04:44:50 pm »
My Ed30 on stage 1 was in the region of 265 ponies so an S3 will have gained (in best Paul Daniels voice) "Not a lot".  :smiley:
« Reply #13 on: July 07, 2010, 04:48:56 pm »
that would be 280bhp on any other rollers  :grin:
« Reply #14 on: July 07, 2010, 04:50:54 pm »
He should notice a difference. Mine drove like it just had a rocket stuck up it's arse as soon as the software was loaded! Maybe the Revo software has a 'little' more punch than Superchips!  :happy2:
