Author Topic: Mapped the s3! Not that blown away?.......  (Read 13835 times)
Offline PDT
  • -Receive: 142
Re: Mapped the s3! Not that blown away?.......
« Reply #45 on: July 08, 2010, 09:07:17 pm »
the dyno lottery is true, however mosr dyno dynamics dynos are within a few % of eachother in most cases.
An engine that is flowing a lot of air doesnt mean its making a lot of power :happy2:
Offline Poppa Dom
« Reply #46 on: July 08, 2010, 09:14:05 pm »
Totally agree :happy2:
Offline MitchGTI
« Reply #47 on: July 08, 2010, 10:48:30 pm »
Well this certainly has opened a can of worms! I think the best thing i can do is get it to a set of rollers and see what its pushing!
been out in it again tonight and its abit warmer and just feels slugish again! Soo my next port of call is a decent CAI and DP then see what its doing? Maybe revo is on the cards after all.... Dom you are wearing on me!!
Offline Poppa Dom
« Reply #48 on: July 08, 2010, 10:52:18 pm »
Sorry Mitch, I will be quiet - though I do think that your car is running just fine - with the map you have but is the map you have optimised as good as it could be. E.g. only requesting 115bar on the fuelling side of things. REckon you should get that downpipe - PM VRStu about the combination he had...
« Reply #49 on: July 08, 2010, 10:54:11 pm »
Just Revo stage 1 and a dp/cat. :smiley:
Offline Janner_Sy
  • -Receive: 113
« Reply #50 on: July 08, 2010, 10:55:03 pm »
id normally say if is sluggish in the heat ,maybe its the intercooler, but you have an S3
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #51 on: July 09, 2010, 12:10:54 am »
It's all relative though Sy. He has a bigger turbo so although an S3 cooler is a good upgrade for a K03 car it starts to suffer on K04 cars earlier.
Or another way to look at it is
Stage 2+ K03 = 280ish Bhp
Stage 1 K04 = 280ish bhp
I think a lot of the reason behind this is that it's being compared to Revo who's files are quite aggressive to give you the feeling you got a lot for your money. Whereas the Bluefin map "maybe" more progressive hence not the same feeling of power (even though it may be quicker) I had this when i went Stage 2+ as i felt it wasn't any quicker. It was only when i did some timed runs i that in fact the car was quicker.
Im not saying that is the case but if the Data Logging is not showing anything a miss then might be an idea to get it on a Dyno to look at the curve and take it from there.
Offline MitchGTI
« Reply #52 on: July 09, 2010, 01:03:15 am »
How does that work with the milly DP will it fit to the standard system with no problems? Will i loose anything by no going full system?
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #53 on: July 09, 2010, 10:29:03 am »
You won't lose anything by not going full system.
All the Cat back part does is make the noise different and improve appearance.
For true stealth just fit the DP. You will prob see about another 10-15bhp & 15-20lb/ft with the DP. Will also help smooth things out due to easier flow.
Offline MitchGTI
« Reply #54 on: July 09, 2010, 11:38:03 am »
yeah i like stealth! im thinkin DP then a CAI and change to stage 2 software? i may have found a ITG intake up for grabs.....
« Reply #55 on: July 09, 2010, 11:38:13 am »
You will need a reducer for the DP/cat to fit.
Offline Kuro
« Reply #56 on: July 09, 2010, 12:06:08 pm »
Yep just needs a reducer to fit... or a have a custom centre section made
Offline gazbutS3
« Reply #57 on: July 09, 2010, 12:53:59 pm »
might as well get a fuel pump on go 2+ :smiley:
« Reply #58 on: July 09, 2010, 01:20:24 pm »
+1, S3's Stage 2+ are monsters  :evilgrin:
Offline MitchGTI
« Reply #59 on: July 10, 2010, 12:56:50 am »
That F*****g slippery slope is in front of me again!!! Argg.  !! Lol kuro ile pm u tomoro about then bits!
