Author Topic: engine/exhaust light  (Read 1318 times)
Offline chopper
« on: July 07, 2010, 08:15:45 pm »
driving home today engine / exhaust light came on. i have edition 30 and had stage 2 bluefin installed 2 weeks ago along with turboback APR RSC , and also have carbonio CAI. car seems to be running fine since all was installed. still seems ok with light on. Any ideas why it might be on? im going to try the bluefin diagnostics on the handset
Saint Steve
Re: engine/exhaust light
« Reply #1 on: July 07, 2010, 08:18:12 pm »
Do you lots of short journeys??
Has the light stayed on since, or went off after shuting down?
« Last Edit: July 07, 2010, 08:20:11 pm by Saint Steve »
Offline chopper
« Reply #2 on: July 07, 2010, 08:21:00 pm »
daily commute is 70 miles. happened about 30 miles in today.
Saint Steve
« Reply #3 on: July 07, 2010, 08:28:42 pm »
Could be an exhaust leak, faulty o2 sensor or lambda sensor on the downpipe.Are you running 99 octane fuel?
Has the light remained on??
Apparenty if you do lots of short journeys , this car occasionally happen as mine has recently done this, but only did it once, and after shutting down, and restarting  ,hasnt come back on in the last fortnight.
Either take the car back where you had the exhaust fitted to get it checked, or get some data logs done from someone with VCDS to assist further.
Offline chopper
« Reply #4 on: July 07, 2010, 08:46:59 pm »
im running bp super unleaded 97 octane. ive tried restarting , but no good. il have to try checking the exhaust for a leak, and then find someone to run diagnostics
« Reply #5 on: July 07, 2010, 09:05:44 pm »
The light can come on for a multitude of reasons.
Best to get the car scanned or diy with the Bluefin handset.
Offline chopper
« Reply #6 on: July 07, 2010, 09:11:45 pm »
ive just tried bluefin handset in the car, and it doesnt have diagnostics on it. can bluefin upload it to the handset?
Saint Steve
« Reply #7 on: July 07, 2010, 09:25:33 pm »
if your running a remapped car, then id put in 99 octane and not 97,
agree with hedge, spek to superchips to enable diagnosis mode on Bluefin handset.
« Reply #8 on: July 07, 2010, 09:52:07 pm »
Chopper have you checked the VCDS owners list to see if there is anyone local you could tap up.
