Author Topic: Possible air-con fault.  (Read 6474 times)
« on: July 08, 2010, 08:50:17 pm »
Very rarely use my aircon probably used it 7 times since new 25 months old. Have used it a couple of times recently and once i switch it off when it gets to nippy, i get a nasty smell in the car about 5 to 10 mins after switch off is this normal or a possible fault.  :sad1:
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
Re: Possible air-con fault.
« Reply #1 on: July 08, 2010, 09:02:33 pm »
Reckon it may be a bacterial build up in the ducts. Common on units not run very often. Try running it for 10 minutes at full fan speed, set as hot as you can. It may help to clear it. Otherwise I'd look to a local independent a/c specialist to 'spring clean' for you. I think this is common on vehicles where the a/c isn't used through winter, or for long periods. The usual advice seems to be use the a/c at least once a week to help stop the buggy build up.
« Reply #2 on: July 08, 2010, 09:08:35 pm »
Cheers Lou.  :happy2:
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
« Reply #3 on: July 08, 2010, 09:10:09 pm »
 :wink: A pleasure TC. Hope you get it smelling pine-fresh soon mate.
Offline Drapoon
« Reply #4 on: July 09, 2010, 11:23:26 am »
You can buy de-bug cannisters cheap from Halfrauds or GSF whch will cleanse the system...
Shut all windows, let cannister off & sit it in your pass footwell with re-circulating air set & air con on max (engine running of course)
Close the doors & wait until the mist clears & this should get rid of the bacterial (eggy!) smell
« Reply #5 on: July 09, 2010, 11:25:47 am »
Might have a go at this.  :happy2:
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #6 on: July 09, 2010, 11:37:01 am »
Ive done this before on mine TC and it worked a treat. Got rid of the damp cloth smell.
Also check the pollen filter isn't damp.
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« Reply #7 on: July 09, 2010, 01:45:58 pm »
As long as it's not a compressor on the way on, you're ok TC  :scared:  :wink:
I'm mid compressor-mare atm  :jumpmove: Oh the joy!
Pete
« Reply #8 on: July 09, 2010, 03:23:30 pm »
I reckon as its not used much id tend to agree with Lou. Deffo sounds like a bacteria build up.
A pollen filter change wont go a miss either!
Just keep it on when your driving TC. saves things like this happening
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #9 on: July 09, 2010, 04:58:12 pm »
...........try this ebay item no 310223672346
« Reply #10 on: July 10, 2010, 07:45:57 pm »
Autoglym are bringing a new product for this. They tried flogging me one when I went to their stand. Which I did only because I couldn't see the Dodo Juice or Autoperfection stands.
