Author Topic: Control Module and Slip ring  (Read 2558 times)
Offline liver
« on: July 09, 2010, 11:22:05 am »
ive tried looking but i cnt seem to find a guide to remove these
ive had the wheel and everything else off but cnt get these parts off so i can fit my cruise control stalk
any help is much appreciated
cheers
liver
Re: Control Module and Slip ring
« Reply #1 on: July 09, 2010, 03:35:37 pm »
Sorry to be vague, but you need to slip a flat knife or something similar down the side of it.
Again, sorry i cant tell you exactly where, but its better than nothing i guess?
Offline liver
« Reply #2 on: July 09, 2010, 03:42:42 pm »
would this be behind the slip ring or the control module or both??
is there a latch or something to detatch??
Offline QD MBE
  • -Receive: 102
« Reply #3 on: July 09, 2010, 04:28:39 pm »
Pm'd you
Offline QD MBE
  • -Receive: 102
« Reply #4 on: July 09, 2010, 04:30:34 pm »
Pm'd you
There are 2 catches to release to get the SW cont off.  I cant explain without pics, but will try to talk you through it,
Offline liver
« Reply #5 on: July 09, 2010, 04:39:25 pm »
cheers i'll give you a bell when im doing it possibly sunday if you don't mind.
i'll drop you a txt first to make sure ur free to chat
Much appreciated thank you
Offline QD MBE
  • -Receive: 102
« Reply #6 on: July 09, 2010, 04:48:19 pm »
http://www.mk5golfgti.co.uk/forum/index.php/topic,10951.0.html
Reply #8 by VRStu, he describes the rear catch, the secret hole they talk of is to the right of the front screw, in fact right and down, stick a very thin screwdriver about 1.5" in and give it a wiggle and this should release the front catch, and the cont should drop away.
D
Offline liver
« Reply #7 on: July 09, 2010, 04:52:24 pm »
thank you will have a go at the weekend
cheers
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #8 on: July 09, 2010, 05:40:48 pm »
D
Yep that's the badboy that catches most people out.  There is also a very small Torx screw on the top right but I'm afraid I can't remember the size.
The second 'hidden' clip can be released by feeling from the back of the controller near the plug with your middle finger and you can push it to release it.
Stu...
Offline mortygttdi
  • -Receive: 146
« Reply #9 on: July 09, 2010, 06:04:45 pm »
that small torx is a T5 :happy2:
Darren
LesleyIlic
« Reply #10 on: May 25, 2012, 08:27:48 am »
Cheers Ung, just the job, I have ring slip just took over maintenance and repair for a client and I am finding things I have never done before still a challenge gets you out of the humdrum
Mac
