November 17, 2024, 03:47:00 pm
All Things Mk5
Mk5 General Area
Anyone had issues with steering wheel rubbing on column cowl?
Topic: Anyone had issues with steering wheel rubbing on column cowl? (Read 1983 times)
nc35
Won't Shut up.
-Given: 40
-Receive: 14
July 10, 2010, 08:23:10 pm »
Hi All
Just finished fitting TC's old steering wheel.
Not a easy with VAGCOM as I expected, but it all works perfectly now.
Except when turning (more than steering) the new wheel rubs on the steering column cowl.
Any ideas what. Have done wrong?
Lee
No Golf anymore.
Enjoyed the last five years of ownership of Mk5 & 6 GTIs.
Plus an excellent forum for knowledge and new ways to deplete the bank account.
Thank You Everyone.
Top Cat
Top cat
Just look at my post count
-Given: 171
-Receive: 335
Almost Jacamo
Re: Anyone had issues with steering wheel rubbing on column cowl?
Reply #1 on:
July 10, 2010, 08:25:06 pm »
Did you take your old wheel off first.
nc35
Won't Shut up.
-Given: 40
-Receive: 14
Reply #2 on:
July 10, 2010, 08:27:35 pm »
Wondered what I had done wrong.
VAGCOM was a bitch. Couldn't clear the error codes for About 1 1/2 hrs.
Then it cleared itself. Can't explain it.
No Golf anymore.
Thank You Everyone.
Top Cat
Top cat
-Given: 171
-Receive: 335
Almost Jacamo
Reply #3 on:
July 10, 2010, 08:29:15 pm »
The only thing i can think of, is you have a slightly different cowl designed before the paddles. Is it the actual paddles catching.
nc35
Won't Shut up.
-Given: 40
-Receive: 14
Reply #4 on:
July 10, 2010, 08:44:10 pm »
No that's the weird bit.
More like I haven't put the cowl back on properly.
I have checked a couple of times.
If you push up on the lower cowl it helps. As we are only talking a mm or two.
Btw screws never arrived. What were they for?
No Golf anymore.
Thank You Everyone.
182_blue
Global Moderator
-Given: 20
-Receive: 54
Reply #5 on:
July 10, 2010, 08:58:36 pm »
Theres two thin strips at the front, or should be, ensure these are properly located, i had it on my edition 30, basically a pin had got bent and was rubbing
Top Cat
Top cat
-Given: 171
-Receive: 335
Almost Jacamo
Reply #6 on:
July 10, 2010, 09:01:59 pm »
Quote from: nc35 on July 10, 2010, 08:44:10 pm
It was just one screw and it held the gubbins to the back of the actual paddle.
mb
Always Involved
-Given: 9
-Receive: 29
Reply #7 on:
July 10, 2010, 09:25:57 pm »
My steering wheel starting rubbing on the cowl for no reason a while ago. I just got a trim removal tool and levered it back, hasn't rubbed since!
All Things Mk5
Mk5 General Area
