Hey folks,
I've recently purchased an Alpine SWE-1000 it's basically an 8" amp/sub combined, you know the underseat style ones... So quite small.
Anyway managed to route all the wires into the boot neatly (rear passenger side when looking into the boot)
I'd like to mount it against the tyre well / on the boot floor but have tried velcro on the lining, and on the sub and no joy, even though it doesn't weigh much, it still won't hold.
It does come with a metal bracket and screws, but surely it's not good to screw/drill into the panels in the boot? Won't it cause rust? It would basically mean screwing a total of 4 screws down into the boot flooring?
Any ideas guys - this is the only thing holding me back as everything else is installed.
Sean :)
PS > I've put the ground wire against the metal handle thing in the boot (the ones either side) I lifted it up, unscrewed one screw, put the ground cable in and then re-screwed it back in, is that where most people use?
