Author Topic: Focus RS500 dyno results  (Read 13238 times)
Offline Janner_Sy
  • -Receive: 113
Re: Focus RS500 dyno results
« Reply #30 on: July 14, 2010, 11:26:50 pm »
i wanna se what the k03 stage 2+ manages at the in gear times.  should have the edge at the low speeds in the high gears id bet until the turbos on the others get upto speed then its bye bye
« Reply #31 on: July 15, 2010, 02:15:16 am »
hurdy what are yours.  surely you have tried these on your performance box.  if not get out and try it :laugh:
Never really thought about "in-gear" times with the DSG, but seeing as I have the DSG stage 2 I can give it a go once the thunderstorms up here die down and the private drive dries out :happy2:
I haven't got a pic of the full 0-100 increments just the best pic with the results as it resets itself, but here is one of a 0-100 that took 10.3 seconds. bare in mind this is through the gears, but if you look at the best times of the other car's and compare them to mine you will most likely be looking at the comparative gears.
            cos/RS/K1/ED30
0-30      1.8/2.5/2.8/2.4
0-40      2.6/3.6/3.7/3.1
0-50      3.5/4.5/4.7/3.8
0-60      4.6/5.6/5.7/4.8
0-80      7.0/7.5/8.7/7.1
0-100  10.7/12.7/12.5/10.3
20-40    1.5
30-50    1.4
40-60    1.7
50-70    2.0
60-80    2.3
70-90    2.9
80-100  3.2
The above are through the gears and the anomoly of the 20-40 being slower than the 30-50 is most likely due to traction up to around 30mph.
Offline Tara
« Reply #32 on: July 15, 2010, 11:45:58 pm »
Hmmmm not keen on the RS!! Bit of a "chav asbo" car :signLOL:
Offline Sunglasses Ron
« Reply #33 on: July 16, 2010, 05:22:41 pm »
I've just had a thought.. Was this RS500 run on JKM's rollers?  :signLOL:
Saint Steve
« Reply #34 on: July 16, 2010, 06:06:56 pm »
^^ glad thats accurate then ben  :wink:  :laugh:
