Author Topic: MFSW telephone button with RNS510 midline and Skoda 729B unit  (Read 5681 times)
Offline Richn83
  • -Given: 49
  • -Receive: 85
Hi all, I am having some issues trying to get the telephone button on my MFSW to answer and hang up calls, firstly going to outline exactly what I have:
RNS510 - 1T0 035 680 B -  firmware 0900 - retrofitted - coded 04000400040000AE00
Steering wheel control module - 1K0 953 549 AG - original - coded 0012142
Skoda bluetooth - 1Z0 035 729 B - retrofitted - coded 0000422
CAN Gateway - 1K0 907 530 F - original - 7F3F03C8070003
Buttons are plastic post 2006 type with the single telephone button, car is 2005 has mid-line computer and has always had DSG paddles.
From my own research I know that some (saint steve) had a similar problem where they tried changing the steering wheel control module or can gateway, but the thread finishes without reaching a conclusion on what fixed the issues.
I do have a couple of common errors across the telephone navigation and can gateway:
Address 77: Telephone        Labels: 5P0-862-335.lbl
   Part No SW: 1Z0 035 729 B    HW: 1Z0 035 729 B
   Component: FSE_2P7x        H31 0050
   Revision: 00000001    Serial number: 00000005009425
   Coding: 0000422
   Shop #: WSC 73430 790 00000
2 Faults Found:
01299 - Diagnostic Interface for Data Bus (J533)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 5
                    Fault Frequency: 28
                    Reset counter: 211
                    Mileage: 51713 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:42:33
00457 - Control Module for Network (J519)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 5
                    Fault Frequency: 5
                    Reset counter: 249
                    Mileage: 51713 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:46:13
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 28001056190129
   Coding: 7F3F0348070003
   Shop #: WSC 01279 785 00200
3 Faults Found:
01305 - Databus for Infotainment
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 3
                    Reset counter: 161
                    Mileage: 47667 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 21:34:37
01304 - Radio
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 161
                    Mileage: 47667 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 21:34:40
And these were also seen by Hedge on Saint Steves car.  Does anyone have any thoughts on resolving this problem?  either coding, or module replacement?   :confused:
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
Re: MFSW telephone button with RNS510 midline and Skoda 729B unit
« Reply #1 on: July 15, 2010, 01:00:48 pm »
the errorcodes is caused by your can bus gateway that is to old for both the rns and bt. i have just installed a revision K canbus gateway which have cleared the fault codes, so can bus should be your first stop. as i have the mk 6 MFSW i can't help reg. the button, but on the mk 6 sw i use ok button to recieve and hang up calls. hope this helps a bit??  :drinking:
Over the top mod list ;o)
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #2 on: July 15, 2010, 01:23:42 pm »
Cheers Danish, the canbus is on the list to replace as I would like to update the RNS firmware.  so that is another plus from making the change, hopefully someone will be along to let me know if this should also sort the button issue.
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #3 on: July 15, 2010, 02:27:35 pm »
I think some of those codes might be due to a poor connection on the CANbus where the phone is wired in.  I don't know if you'll get the phone button to work.  Changing the coding on the Steering Controller for CC will make the Star button act as the phone button as shown in the guide on my website.
Stu...
  • -Given: 243
  • -Receive: 154
« Reply #4 on: July 15, 2010, 02:40:06 pm »
i had same codes with same parts, they dissapered when i changed canbus gateway  :smiley:
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #5 on: July 15, 2010, 02:53:25 pm »
Thanks Stu,  Will check the wiring and try to make sure there is a good connection.  I changed the coding on the steering controller last night, and the star button went from mute to voice control so both the 2 and 4 configuration.  I also dont have the phone book in the module to use voice dialing but think this might be a phone and RNS issue rather than something related to these issues.
I did use your guide to fit the unit so a big thank you for the excellent site  :notworthy:  Do you know what the issue is with the phone button is it just the button and signal being different between the VW and Skoda kit, for example if I had put the VW equivalent in the car I wouldnt be having this issue (although my phone wouldnt have worked with it!  :grin: )
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #6 on: July 15, 2010, 07:13:39 pm »
I think it's just something to do with the software of the MFSW not utilising the function of voice control.
Stu...
Offline golfman
  • -Given: 17
« Reply #7 on: July 16, 2010, 02:31:29 pm »
I dont think you will get the phone button to work as its a skoda kit you are using in a vw,ive been trying for years to get it to work,if it was a vw phone kit it would work fine :happy2:
scott
Vag-com Hex+Can in scotland
I Hate Timewasters...
