Author Topic: Shorter drop links required when lowered?  (Read 2461 times)
Offline conneem
« on: July 15, 2010, 11:10:51 am »
Hi,
I have a MKII TT lowered on KW V2 coilovers and am getting some clunking sounds from the front left suspension when going over bumps with a lock on.
I had a look and this is what I can see is happening. The drop link and front arb seem to be hitting other components. The top of the drop link is hitting/rubing against a plastic shield and the arb against the Xenon leveler.
I think I need some adjustable/shorter drop links but haven't heard of this much with other TT's or GTI's. Has anyone else on here had a similar problem? And does anyone know of any adjustable drop links available for the MKV GTI.
Here is a pic of what is happening.
Offline GTIjames
Re: Shorter drop links required when lowered?
« Reply #1 on: July 15, 2010, 11:50:18 am »
Ksport do adjustable front end links for the mk5gti  :happy2:
Got mine earlier this year direct from them in the USA as their uk rep was useless
Worked out about £70delivered i think
They are shorter than stock but then can be adjusted to lenghthen them
http://www.ksportusa.com/asp/endlinks_detail.asp?product_id=el01
« Last Edit: July 15, 2010, 11:56:11 am by GTIjames »
