Author Topic: The ultimate Dyno Graph thread  (Read 289113 times)
Offline Janner_Sy
  • -Receive: 113
Re: The ultimate Dyno Graph thread
« Reply #120 on: February 18, 2011, 06:30:10 pm »
if you not nailing it all the time do you really need the cooler?
If you nail it, flick on the WMI, for instant cooling.
With REVO if you run out of meth you can manually retard the ignition timing.  then just run it on diostilled water for the cooling effect.
Offline damoegan
« Reply #121 on: February 18, 2011, 06:37:30 pm »
You can run WMI without any meth in it and just use it for cooling....
Edit: Sy beat me to it...
Offline RagingKileak
« Reply #122 on: March 14, 2011, 07:51:57 pm »
Hurdy's old car (now mine) fully setup to Stage 2+ on Friday.
Nice torque figure and feels lovely and smooth.
Regards
Matt
Offline johnhol78
« Reply #123 on: April 06, 2011, 06:10:09 pm »
Standard GTi 55 Plate
Paramount Performance Custom Map (Their Stage 1 so to speak)
Pipercross Panel Filter
Dyno Dynamics
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #124 on: April 30, 2011, 02:17:41 pm »
Right, finally my turn, I have recently gone from APR K04 conversion software to REVO and after a dodgy throttlebody and some bad spark plugs we are on the right track:
Car:  VW Golf GTI 2006 TFSI Engine code AXX
tuner/stage/settings Revo stage 3   Settings:b-9 f-9 t-6
Modifications  K04 turbo conversion, Twintake, APR RSC 3" TBE, APR intercooler, S3 injectors, APR HPFP, Forge K04 actuator, BSH throttlebody pipe, BN autoteknik turbo discharge, Neuspeed pulley kit, Sachs SMF
Type of Dyno/operator  ?
miscellaneous details : defect intake manifold runner,
I'm content, after struggling with lots of bad karma, it seems like i'm on the right track.  :party: I still feel that i could optimize the setting of the Forge K04 actuator, so hopefully some improvements there  :innocent:
« Last Edit: April 30, 2011, 02:20:08 pm by danishmkvgti »
Over the top mod list ;o)
Offline chungster
« Reply #125 on: April 30, 2011, 05:52:11 pm »
Roc R with Revo S1 on conservative B6 T3 F5 settings / Twintake / Twintercooler / Milltek Cat Back
Charlie's words were "it needs a bit more timing there's more in there" lol but I've purposely held the timing back to protect the fragile clutch.  :grin:
But it's good and happy with that. However i got spanked on the torque front by another Roc (small turbo too....grrrr )  :signLOL:
PS: graph in easy to read scaling too (which took 5 secs to do on the computer!)
« Last Edit: April 30, 2011, 05:54:34 pm by chungster »
Offline Sunglasses Ron
« Reply #126 on: May 01, 2011, 11:19:39 am »
F5 on standard pump?!?!  :surprised:
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=up2qgih4arg32ncjvt6gbel6dc&/topic,19740.0.html
« Reply #127 on: May 01, 2011, 11:32:11 am »
Lee.. thats a very good result!  :happy2:
Offline PDT
  • -Receive: 142
« Reply #128 on: May 01, 2011, 11:39:50 am »
Chungster, is the date correct on that graph? If so the B.P (barometric pressure) reading is still in default 98.0, whereas the true barometric pressure would have been approx 101.5 on that date.
May be worth contacting them and letting them know their weather station could be faulty :happy2:
« Reply #129 on: May 01, 2011, 11:45:26 am »
What result would that have on the graphs?
Offline PDT
  • -Receive: 142
« Reply #130 on: May 01, 2011, 12:07:02 pm »
Depends on the overall value of weather compensations on the day, the power of the car and other factors. it may not even be incorrect but 98.0 is extremely low for this time of year.
JKM wrote a bit about this here:
http://www.jkm.org.uk/performance/dynotesting.htm
And based on the weather station in Surrey on this date, baro pressure was around 1014.0 but thats not to say that the pressure in the dyno room was the same, fans and extractors will change the BP. I made the mistake once of leaving my weather station in a box in the boot of my car and then testing a car on the dyno directly after using the info on the weather station before it had had a chance to settle. The weather station read much lower than the true BP and the car was over reading by approx 20%. a quick check of the atmospheric conditions found the problem.
I also had a faulty weather station, it reads around 15 lower on the BP than the Dyno Dynamics one, when testing cars with the incorrect BP figure they usually gain around 12% of power.
Its good practice to check the Bp on your weather station against the local weather stations readings. I now have 3 weather stations, 2 that are correct and I use to cross check each other and my faulty one that use to show people what effect the weather conditions can play on dyno results.
P.s my faulty one occasionally defaults to 98.0 and stays there for days before reading a different figure, this is what drew my attention to the 98.0 figure on your graph, its an odd figure to see at this time of year with the weather we have had lately.
Offline chungster
« Reply #131 on: May 01, 2011, 12:21:37 pm »
Yup have queried it already, but it's how this dealer sets it up on the OE pump. I might up the timing and change to F9 and see how it goes
Offline chungster
« Reply #132 on: May 01, 2011, 12:23:21 pm »
Will send Charlie your comment and see what he says  :happy2:
Offline wigit
  • -Given: 129
  • -Receive: 42
« Reply #133 on: May 01, 2011, 02:46:26 pm »
I wouldn't worry about the figures Chungster got PDT given my TSI revo stage 2 we got around 9bhp less than the mk6 GTI you posted here 5 mins before ;)
Offline PDT
  • -Receive: 142
« Reply #134 on: May 01, 2011, 06:13:59 pm »
Not worried about figures, but if thete is a problem with the weather station at that dyno it would be nice to let them know :smiley:
