Author Topic: The ultimate Dyno Graph thread  (Read 291907 times)
Re: The ultimate Dyno Graph thread
« Reply #255 on: March 07, 2012, 08:43:55 pm »
Keith is taking my car next week to improve the dip at high revs  :notworthy:
Hopefully not improve but REmove.  :happy2:
Keith,
I may have the ITG heat shield removed to see if there is a slight change it is not getting enough airflow at high revs.  I dont think this is the case but will see if it  has any impact
Offline 56OctyVRS
  • -Receive: 72
« Reply #256 on: March 09, 2012, 12:43:39 am »
I had the itg heatshield on my car and took it off. I found it felt crisper with it removed.
« Reply #257 on: March 09, 2012, 11:38:24 am »
Mcoys or Walkers?
If it felt Mcoys Flame grilled steak I will remove the heat shield lol
Offline 56OctyVRS
  • -Receive: 72
« Reply #258 on: March 09, 2012, 12:32:53 pm »
Its not McCOYS crisp. Im talking Flamin hot monster munch crisp :party:
Offline TT-Turbo
« Reply #259 on: March 09, 2012, 12:41:19 pm »
Thought I might as well add my dyno sheet after the remap.
2008 Audi TT 2.0tfsi K03
Current engine work- Stage 2 Revo, 3" TBE blueflame Zort, ITG big mother intake, Neuspeed power pulley, Neuspeed intercooler pipe, Colder grade spark plugs, rev D DV.
It has had a lot of other non dyno related work done to the car too.
I must admit I think this dyno sheet is a little optimistic on the torque figure but the BHP seems about cock on really. I have changed the timing a lot since then and it has gained a lot more power through the rev range. Came away with the timing set to 2 and now is set to 5 and runs really well.
Only problem is the clutch started to slip just after 2K miles! It does seem to have a lot of torque in general so I don't think that dyno sheet is lying completely. Would be interested to hear some thoughts on this.
Next few mods- Upgraded clutch, Quaife diff, Intercooler, Upgraded HPFP, stage 2+.
Here is a couple pics of the intake as it really does look fantastic, a nice 5" bore intake!
And couple pics of the car-
Offline 56OctyVRS
  • -Receive: 72
« Reply #260 on: March 09, 2012, 12:48:52 pm »
That intake looks awesome and a proper Cold air filter.  Where did you buy that from and how much? One like that may find its way on to my car :drool:
Offline TT-Turbo
« Reply #261 on: March 09, 2012, 01:05:14 pm »
Thanks buddy! I've been hassling ITG for about a year to make one for the TT and when thinking about getting a kit for the TTRS they said they would like to use my car to figure out the various fitments that are needed for this. So the kit is now available to buy for a TT but I think the price tag is around £500! Definitely worth it, as you said it's a proper cold air intake now with a massive 5" bore! They redesigned the slam panel intake scoop to allow higher volumes of air too. ITG really have thought of everything and the kit really is a piece of art!
Offline james
« Reply #262 on: March 23, 2012, 11:22:54 am »
BWA + k04 + MWI
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #263 on: March 23, 2012, 04:20:18 pm »
Are you ED 30 guys upgrading your hpfp's to reach 330bhp+ or is your cam, having a different fuel lobe, providing proper fuel pressure?
I've been trying to figure out how you all get your power with no mention of hpfp upgrades. Plus there doesn't seem to be as much of an issue with your cam followers wearing through like we have here in the states. I know that your Ed 30 intake cam has a larger fuel lobe on it and the hpfp is the same as our GTI. I want to replace my cams with the new golf R's cams, but should I go back to the oem hpfp to be able to once again get longer life from my followers? Right now with an APR hpfp I need to replace the follower every 10k miles due to wear.
« Last Edit: March 23, 2012, 04:48:41 pm by ROH ECHT »
Offline james
« Reply #264 on: March 23, 2012, 04:32:47 pm »
yea mine is a GTI, with a k04.   But  yes you have to upgrade your HPFP
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #265 on: March 23, 2012, 04:47:06 pm »
Right, GTI's need to do the hpfp upgrade, I meant to ask the Ed 30 guys if their cams having larger fuel lobes is enough. Trying to figure out if there is an otion to the hpfp upgrade. Can a GTI w/K04 simply switch the intake cam w/larger ED 30 lobe and the stock ED 30 hpfp give the same results.
« Last Edit: March 23, 2012, 04:50:59 pm by ROH ECHT »
Offline james
« Reply #266 on: March 23, 2012, 04:51:08 pm »
you just need to upgrade your fuel pump mate, that is it.
i am pushing 396BHP at the fly.
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #267 on: March 23, 2012, 07:30:11 pm »
@ ROH, the cams are the same as yours regarding the hpfp lobe, if the ed30/leon Cupra/S3 were different and giving higher pressure, they wouldn't be needing the rs4 fuel pressure valve  :wink:
Over the top mod list ;o)
Offline 56OctyVRS
  • -Receive: 72
« Reply #268 on: March 23, 2012, 08:55:22 pm »
RS4 Valve. One of the best mods Ive done :happy2:
Offline heavyd
  • -Receive: 29
« Reply #269 on: March 23, 2012, 09:11:13 pm »
What difference did it actually make if you don't mind me asking? I was told is wasn't worth bothering with :stupid:
