Author Topic: The ultimate Dyno Graph thread  (Read 297420 times)
Offline yin
  • -Given: 77
Re: The ultimate Dyno Graph thread
« Reply #435 on: August 22, 2014, 10:03:50 am »
When will the TTE Cupra be done  :party:
I think Brian has it booked in next week :)
Have I read on here that you are using revo on it?
Offline yin
  • -Given: 77
« Reply #436 on: August 22, 2014, 10:04:52 am »
Stage 2+ edition 30 with latest Revo update
Is this a recent revo update to 2+
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #437 on: August 22, 2014, 10:37:16 am »
Yes, it has REVO stage 2+ and will use that for the TTE 420 turbo  :happy2:
Over the top mod list ;o)
Offline heavyd
  • -Receive: 29
« Reply #438 on: August 22, 2014, 02:42:05 pm »
No idea how recent it is. I was advised to get an update by statllers. When I phoned Revo, they said I had revision 5, they were currently on revision 12 for my car, so he also advised me to get it done.
Graph shows old stage 2+ with 5 week old vpower in the tank. The latest run was same settings, latest revision, and car had just been serviced
Offline robern2
« Reply #439 on: August 23, 2014, 08:45:22 am »
So there are multiple revo stage 2+ versions.
If you already have revo stage 2+ are revo allowing upgrades to the latest version if applicable ?
Offline wattso
« Reply #440 on: August 31, 2014, 11:46:44 am »
K03 gti
Shark stage 2 remap
Forge twintake
Miltek non res full tbe with 200cell sports cat
Revised dv valve
Not very good at interpreting the results if anyone can help out, I believe this graph is at the wheels which translates to ~250bhp, BUT  he did say the env temp was 26 degrees so add ~ 10% hp to compensate. So we reckon 270 Bhp  :happy2:
Can anyone make sense of the torque for me, doesn't seem right!
« Last Edit: August 31, 2014, 11:50:46 am by wattso »
« Reply #441 on: August 31, 2014, 02:05:57 pm »
Looks like it's calibrated in Nm although it written lb ft on the printout.
490Nm equates to around 361lb ft
Offline wattso
« Reply #442 on: August 31, 2014, 02:28:27 pm »
Thanks mate, that makes perfect sense! How does the graph look otherwise?
  • -Given: 243
  • -Receive: 154
« Reply #443 on: September 01, 2014, 01:42:27 pm »
Seat Leon Cupra, TTE420, BCS powervalve 3", Evoms, S3 IC, 1,5 Bar boost, Real EGT 850 Celsius
Offline audiman
« Reply #444 on: September 01, 2014, 09:26:56 pm »
Crank or wheel hp??
Who tuned it?
Mk5 GTi ED30 - 360ps
B7 RS4 supercharged - 650ps
Mk2 GTi 4motion 1.8T - 450ps
  • -Given: 243
  • -Receive: 154
« Reply #445 on: September 01, 2014, 10:19:08 pm »
Crank or wheel hp??
Who tuned it?
Built by BNAutoteknik.dk as it states on the graph, crank
Offline audiman
« Reply #446 on: September 03, 2014, 12:00:02 am »
Sorry, didn't realise they were actually tuning it.
The numbers seem low for the tte setup. Is there a reason behind that?
Offline Shorty
  • -Receive: 24
« Reply #447 on: September 03, 2014, 11:11:14 am »
Think it works out at 385bhp 385lb/ft.
On a Revo 2+ tune and that boost I'd say that's a very good figure, more boost and a bespoke map would see over 400bhp I'm sure and a lot better torque/power spread than a standard K04, it's not all about peak figures is it.
| Mk7 R |
Offline audiman
« Reply #448 on: September 03, 2014, 01:33:53 pm »
I didn't know it was still running the revo 2+ software. That's why I asked who was tuning it. I wouldn't have bothered making comment if I knew it was only on the revo file.
So in other words, when it actually gets tuned properly it should be doing some impressive figures.
I was interested to know as my k04 setup is maxed out and would like to upgrade to the tte420. The torque spread is nice, be nice to see what happens with a good custom tune to the top end. The k04 feels lacking at higher revs, which is what the tte should solve
Offline Shorty
  • -Receive: 24
« Reply #449 on: September 03, 2014, 03:03:04 pm »
What power/boost are you at with your K04?
That TTE420 Graph is only a 1.5 bar peak too and EGT's are high but not massively high for a K04. So I'd say there's a good bit to come with mapping, more boost and meth.
When I had my BBT hybrid I made 391bhp 385lb/ft at 1.65/1.7 bar peak and meth with a R Tech custom file, so this TTE420 looks promising.
I'll upload a pic of my graph, it had a nice power and torque curve.
| Mk7 R |
