Author Topic: The ultimate Dyno Graph thread  (Read 289265 times)
Offline Johnsy
Re: The ultimate Dyno Graph thread
« Reply #480 on: December 29, 2015, 11:09:01 pm »
Car:-Seat Leon Cupra R (mk2)
Tuner/stage/settings:-Big Fish tuning/stage 1/unknown settings
Modifications:- None really
Type of dyno/operator:-vtech dyno/Big fish tuning
Misc:- standard map was running +5.3deg timing advance which I believe was holding the car back slightly,
https://www.dropbox.com/s/lh0556007dbhhba/Seat%20Leon%202.0%20TFSi%20265-304bhp%20%2B110nm%20Torque.pdf?dl=0
Never used Dropbox before so hopefully the graph works
« Last Edit: December 29, 2015, 11:24:39 pm by Johnsy »
Offline jasam
  • My Ride: 2.0 tfsi k04, revo stage 3
« Reply #481 on: January 25, 2016, 06:13:23 pm »
It seems my maf readings are not showing correct power. It shows around 300 bhp.  I tried with other 300, 330 bhp cars (also manual gearbox) and my engine must have around 330ish bhp. I have twintake. Strange , because other cars with same inlet, showed correct power on maf
Offline jacobrownoly
« Reply #482 on: February 08, 2016, 05:34:24 pm »
Mk5 gti
Revo stage 2+
B8:T5:F6
Revo Intake
Decat downpipe with standard catback
Autotech HPFP
R8 coils
Airtec stage 2 intercooler
Really chuffed!  :jumpmove:
« Last Edit: February 12, 2016, 02:00:29 pm by jacobrownoly »
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #483 on: February 18, 2016, 10:57:32 am »
Mk5 Golf GTI Edition 30 DSG
MB Power custom remap
Engine mods:
  • ITG Profilter panel filter (WB586)
  • OEM airbox lower face insulated with heat insulation tape
  • Darkside Developments S3 uprated IC with alloy end tanks and silicone boost hoses
  • NGK Iridium BKR7EIX spark plugs
  • R8 red ignition coil pack set
  • LOBA's HPFP
  • RS4 fuel pressure regulator valve
  • CTS Turbo intake manifold runner flap delete kit
  • CTS Turbo throttle pipe
  • CTS Turbo turbo outlet pipe
  • Forge Motorsport oil catch tank system for vehicles with charcoal filter (FMMK5CTC)
  • Creations Motorsport Exhaust manifold heat shield
  • BCS Powervalve TBE Prestige system with 200 cell cat and wrapped DP
  • Vibra-Technics bottom engine mount/Subframe mount (VAG520M)
  • Vibra-Technics dogbone mount (VAG455B)
  • DSG remap to allow more torque
It now has 330 BHP and 457 Nm/337 lbf*ft, with 1,5 bar of peak boost and 1,4 bar of stable boost.
The numbers seem to be similar to other tuners stage 2. I'm waiting for a map more like a stage 2+. Not sure if the lack of a CAI will hinder my desire. For this level of tune the OEM airbox is enough.
Offline The Wanderer
« Reply #484 on: March 18, 2016, 07:00:27 pm »
2.0litre TSFI
Loba 10.5:1 forged pistons
PEC steel rods with ARP bolts
ACL race bearing big end bearings
Balance shaft removal
Stock head, valves, cams
1.8T oil filter conversion with external cooler kit
S3 injectors
K04 race developed hybrid
PWR charge cooler
custom map for linear power for lightweight vehicle, turbo at 1.7 bar
« Last Edit: March 18, 2016, 07:41:04 pm by The Wanderer »
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #485 on: March 18, 2016, 07:10:51 pm »
2.0litre TSFI
S3 injectors
400bhp Exige??! I bet that's one hell of a drive.
« Reply #486 on: March 18, 2016, 07:44:03 pm »
2.0litre TSFI
S3 injectors
It is a flying machine - weighing only 900kg - the tuner could of got more power out of it but we think it is suffering from valve float, it is ok at this level though.
cheers
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #487 on: March 19, 2016, 05:04:11 pm »
That'd be quick with half the power. Think my next car might have to be something rwd and light. As good as the mk5 gti is, it's still limited by its front drive, and it's not exactly light!
Offline Scoobykiller
« Reply #488 on: June 12, 2016, 01:41:58 am »
Mk5 gti
Byd engine
Ko4 turbo
S3 injectors brakes etc
K&n filter and evoms intake??
Vf engineering heatshield
Apr exhaust
200 cell sports cat
Apr hpfp
Apr exhaust
Offline jasam
« Reply #489 on: October 04, 2016, 09:26:58 pm »
scoobykiller, which remap you have? power seems great...
edit: Now I see its not bwa :)
« Last Edit: October 04, 2016, 10:19:17 pm by jasam »
Offline cupra_matt
« Reply #490 on: November 19, 2016, 03:17:12 pm »
Car:  VW Golf GTI Edition 30 DSG 2.0 TFSI
tuner/stage/settings: R Tech Stage 2+
Modifications :
Revo camcoat intake,
Auto tech HPFP, RS4 FPR,
3.5" Relentless decat,
3" resonated scorpion exhaust,
Welly cooler.
Type of Dyno/operator: Bosch, Niki Gower
Ambient temp: 7.5 degrees
Offline sean.smithy94
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,107823.0.html
« Reply #491 on: February 10, 2018, 09:06:23 am »
Car:  VW Golf GTI MK5 KO3
Tuner/Stage/Settings:  R-Tech Stage 2
Modifications:  Backbox Delete, Oversized Ramair Intake, BCS 3" sports cat and dp
Type of Dyno/Operator:  Niki Gower
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #492 on: February 10, 2018, 04:59:11 pm »
RPM Power Engine Management custom remap
Engine mods:
  • VW Racing cold air intake (VWR12G5GT)
  • Go Fast Bits DV+
  • LOBA's HPFP
  • DSG remap
It made 367 BHP and 499 Nm/368 lbf*ft.
This is a graph comparing the WHP difference between the previous tune (red) with the CAI fitted and 345 BHP with the current tune (blue).
It's now much faster at mid range rpm than before. :evilgrin:
Offline Adam41kLat
« Reply #493 on: September 12, 2018, 10:12:18 am »
Guys please note that this is a before graph with a base map and an after with a dyno tuned map. No NOS in these runs.
Offline djcamgti
« Reply #494 on: July 20, 2019, 09:56:35 am »
Mk5 golf gti manual
Revo stage 1 c (use of v power fuel)
RamAir 90mm induction kit
GotBoost Dyno
