Author Topic: Revo select switch Stage1 to stage2  (Read 1320 times)
Offline berttie21
« on: July 18, 2010, 07:31:36 pm »
Does anyone know the answer to the following situation.
I had a stage 1revo remap and at the same time I purchased a select switch. I have now upgraded to a stage2 remap but did not hand in the switch for an update. I have a service tomorrow so I want to revert back to stock, I am guessing that when I receive the car ba k and insert the switch I will only get an stage 1 map?
Is there any way to update the switch remotely or do i need to return it to the mappers?
Berttie
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: Revo select switch Stage1 to stage2
« Reply #1 on: July 18, 2010, 09:44:56 pm »
Switch has nothing to do with what software is on the car.
Setting stock will put the car to stock.
Setting performance will set REVO default performance which is iirc B6 T2 F9
Those settings will give differen power outputs at Stage 1 & Stage 2 the map is on the ECU not the switch. The switch gives you the ability to alter the map within a defined set of parameters. (1-9 on B T F )
I've had my switch since stage 1 and I'm now stage 2+ and never updated the switch
« Last Edit: July 18, 2010, 09:47:00 pm by vRS Carl »
