Author Topic: DV Fitting  (Read 8256 times)
Offline j46ger
Re: DV Fitting
« Reply #15 on: July 21, 2010, 11:56:14 am »
cheers edd
Offline Britishlion
  • -Given: 36
  • I have an eBay business !
Re: DV Fitting
« Reply #16 on: July 21, 2010, 12:19:50 pm »
Is there a How To guide for doing this yourself
for a GTI !
While your on the the best GTI forum, get your wife to peruse my.
http://stores.ebay.co.uk/BRIGHTSPARKS-CONSULTANTS-WEB-STORE
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: DV Fitting
« Reply #17 on: July 21, 2010, 12:23:29 pm »
No but it's easy enough to do Stefan
Just put car on Ramps/Axle Stands
Remove under tray
Turbo is on rear drivers side of the engine. DV is attached to that.
Remove 3 bolts holding it in. Replace with new DV and then refit under tray (make sure you reconnect the elec connector)
Job done. Will take around 45-60 mins to do yourself.
Offline Britishlion
  • -Given: 36
Re: DV Fitting
« Reply #18 on: July 21, 2010, 12:25:29 pm »
Remove under tray
Guess what i'm doing Saturday !
Thanks Carl
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: DV Fitting
« Reply #19 on: July 21, 2010, 12:53:42 pm »
Just make sure you have the Correct tools.
If you get stuck give me a bell and i'll talk you through it :happy2:
Offline Britishlion
  • -Given: 36
Re: DV Fitting
« Reply #20 on: July 21, 2010, 12:57:39 pm »
 :notworthy: :notworthy: :notworthy: :notworthy:
Offline SeanyK
  • -Given: 35
Re: DV Fitting
« Reply #21 on: August 22, 2010, 11:19:36 pm »
How about jacking up the car driver side, removing wheel, take off wheel arch lining and get to it from there? Any easier?
gaz b
Re: DV Fitting
« Reply #22 on: August 23, 2010, 05:38:31 pm »
I was lead to believe that was the easiest way too! :confused:
Offline SeanyK
  • -Given: 35
Re: DV Fitting
« Reply #23 on: August 23, 2010, 05:56:47 pm »
We will soon find out mate as I am doing mine on Saturday!  :popcornsoda:
Offline bodger00
  • -Receive: 20
  • A wish called Zonda
Re: DV Fitting
« Reply #24 on: August 23, 2010, 06:52:48 pm »
Let us know which way is easiest :happy2:
gaz b
Re: DV Fitting
« Reply #25 on: August 23, 2010, 06:56:54 pm »
Maybe sooner than that!
I get mine tomorrow, so if its dry I'm all over it like a rash! :evilgrin:
gaz b
Re: DV Fitting
« Reply #26 on: August 24, 2010, 05:42:29 pm »
Right, just fitted my new valve and as the churchill dog says "ooooooooooooh yeeeeeeeeeesssss!" :driver:
New and old. (hole on old green one, bottom left)
  Car now pulls like it did when I first put the bluefin on.  Mine had one pretty big hole in it as you can see from the pics. (held open with allen key!)
 I did not remove any wheels or covers or trays to access the valve. Maybe mine are missing? :ashamed: I did however use the pit at my parents house. (left over from the old stock car days)  Pretty awkward to get to the top bolt but if you persist you will be fine!
One allen key and some tread lock - job done. :happy2: well under an hour and I wasn't sure where it was! :confused:
With Valve off.
New valve on. (tried to show it in relation to the front drivers wheel)
HTH :wink:
« Last Edit: August 24, 2010, 05:44:48 pm by gaz b »
Offline bodger00
  • -Receive: 20
Re: DV Fitting
« Reply #27 on: August 24, 2010, 08:04:03 pm »
Thanks Gaz. Thank you given. Although not sure I can see it in the pics :rolleye:
gaz b
Re: DV Fitting
« Reply #28 on: August 24, 2010, 08:36:11 pm »
Ha! David Bailey I aint! :grin:   Next to the small silver pipe, The red wires are the plug that fits in to the DV valve. The plug points downwards. :smiley:
Like I say tried to show the location of the DV valve in relation to the front wheel. I basically had to go under the car and look for what I thought might be the valve. Easy to find , just a little awkward to get to. :drinking:
Offline micaerin
  • -Given: 19
Re: DV Fitting
« Reply #29 on: September 10, 2010, 11:55:37 pm »
i found this if it helps
http://www.carworklog.com/?p=51
2007 GTI DSG, Xenon's, Armrest 6 Disc ,Rear Parking Sensors,Sunroof,Lux Pack,Cruise,Electric drivers seat,MFSW,RNS 510,Miltek Cat Back.
