Author Topic: 2.0 TFSI Injectors  (Read 10201 times)
Offline keith
2.0 TFSI Injectors
« on: January 27, 2009, 09:07:10 pm »
When I was at Inters last year I saw Autotech 2.0 TFSI Injectors( pic below), now i believe you can fit bigger injectors when you go BT but wondered what the ED30 has as standard compared to the S3 & Cupra.
JKM sells OEM Audi S3 ones  and the Autotech version looks to be a modified VAG part.
Offline Toast
Re: 2.0 TFSI Injectors
« Reply #1 on: January 27, 2009, 09:14:38 pm »
I saw these to Keith :happy2: As far as I thought the ed30 and s3,cupra r all had the same injectors?
Toast
Offline keith
« Reply #2 on: January 27, 2009, 09:40:37 pm »
so are the Auotech versions uprated to go with the fuel pumps.
« Reply #3 on: January 27, 2009, 09:48:21 pm »
That was my impression as well.
If you go beyond a K04 then you use RS4 injectors.
Offline Toast
« Reply #4 on: January 27, 2009, 09:52:02 pm »
Keith as far as I'm aware you don't have to upgrade the injectors when you do the pump I was pestering Jim about the pump on Sunday still waiting on them coming into the uk
Bacillus- thats right there's a few boys on the Audisport forum runing Rs4 injectors in there s3's
Toast :happy2:
Offline garethmk1
« Reply #5 on: January 27, 2009, 11:07:52 pm »
Interesting stuff - will remember the RS4 injectors for when it gets a GT3071R after the warranty runs  :evilgrin:
Mk5 Golf GTi Edition 30 No:- 2101, 3Dr, Tornado Red, Rear Tints, RCD510 & Sound Pack, Arm Rest
Mk1 Golf GTi 16v Helios Blue, Too Many Mods To List .... MY First Car ! Owned Since 1996 !!! NEARLY READY !!!!!
Offline Toast
« Reply #6 on: January 27, 2009, 11:28:08 pm »
Gt3071r,Rs4 injectors,Diff,Uprated clutch= :evilgrin: :evilgrin: :evilgrin: :evilgrin:
High 5 to that brother my kind of thinking :driver:
Toast
« Reply #7 on: January 28, 2009, 09:41:43 am »
Good plan but no tuner over here seems to have readily available software for that upgrade...   :happy2:
« Reply #8 on: January 28, 2009, 09:45:13 am »
To Keith, remember that the US doesn't have the ED30 engine so my guess is those  injectors are meant for guys who upgrade their k03 turbos to the k04 ones.
Offline jonnyc
  • Herrooooo!
« Reply #9 on: January 28, 2009, 04:02:51 pm »
ED30/S3/Cupra all have the same injectors, which flow 15% more than the standard K03 engine's injectors..
When I had the GT2871R turbo on the S3 I had RS4 injectors. No probs at all..
They are good for supporting up to 500WHP ish.. But after that you need a high flow in tank pump and even bigger injectors..
Jonny
Offline neg
  • gone old skool
« Reply #10 on: January 28, 2009, 08:24:21 pm »
Jonny
and probably a bigger tank too  :laugh:
Offline WhiteGTI
  • F-A-S-T
« Reply #11 on: January 28, 2009, 08:26:49 pm »
So could I put the S3 or the Autotech injectors on my normal GTI? And what benefit would I see?
2006 E46 BMW M3 - 343hp
« Reply #12 on: January 28, 2009, 08:31:06 pm »
none...
Offline WhiteGTI
  • F-A-S-T
« Reply #13 on: January 28, 2009, 08:37:34 pm »
none...
Jonny says above that they flow 15% more than K03 injectors though? So that still equates to no benefit?  :ashamed: :chicken:
« Reply #14 on: January 28, 2009, 09:35:41 pm »
Ever wonder why the big tuners don't offer injector upgrades for k03 cars?
The k03 doesn't maximise its present oem injectors so using bigger injectors won't give you any more peformance.
