Author Topic: Diaphragm check - fail  (Read 1895 times)
Offline punkeyfunky
« on: July 24, 2010, 09:48:16 am »
I can't even get the fsckin' engine cover off! :(
Offline ub7rm
  • -Given: 35
  • -Receive: 43
Re: Diaphragm check - fail
« Reply #1 on: July 24, 2010, 11:35:32 am »
It helps if the engine is warm but you really have to pull.  Start at the back right.  Once that one is free the rest are easier.
Unless you have an ed30, you dont need to take the engine cover off to check the dv.
Sepang Blue S4 BE Avant
Offline punkeyfunky
« Reply #2 on: July 24, 2010, 11:57:05 am »
Thanks for that; I do have an Ed30, but I can't see the DV; I don't know exactly what I'm looking for y'see... ;)
-Lee
Offline cmdrfire
    • Commander Fire - my blog
« Reply #3 on: July 24, 2010, 01:03:23 pm »
Get a firm hold of it, and then give it a hard yank.
When it comes to putting it back on, lube up the mount points and push it on there hard.
/that's what she said?
Nasir
« Reply #4 on: July 24, 2010, 01:18:30 pm »
The DV on the Ed30 is a long hose on the left hand side of the engine. Like in this image:
http://www.egmcartech.com/wp-content/uploads/2007/05/2007_volkswagen_gti_pirelli_official_6.jpg
Offline punkeyfunky
« Reply #5 on: July 24, 2010, 01:49:26 pm »
Thanks for the advice.  Left the engine cover where it is, and found the DV.
The DV appears to be just fine; no splits or cracks or tears.
-Lee
Offline markc
« Reply #6 on: July 24, 2010, 04:57:21 pm »
I've not checked mine yet.
I take it you remove the front air intake pipe first, engine cover, then the star screws on dump valve ?
Had: Edition 30, 3 Door Manual, Pearl Black, Cruise Control, IPod Prep, Arm Rest, Auto Lights and Wipers
Offline punkeyfunky
« Reply #7 on: July 24, 2010, 06:50:48 pm »
No need to remove the engine cover on the Ed30, otherwise, as you've written :)
-L
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #8 on: July 24, 2010, 09:50:28 pm »
Hmm, I would have thought better access from underneath on the Ko3 turbo's.  I certainly wouldn't be attacking it from the top.
Stu...
Offline gazbutS3
« Reply #9 on: July 24, 2010, 10:11:24 pm »
I changed a K03 DV yesterday, and its an axle stand and wheel off job, then its a struggle but not to bad :smiley:
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #10 on: July 24, 2010, 10:14:07 pm »
I would normally just jack up and reach up from underneath.
Stu...
