Author Topic: how to remove retainer clips?  (Read 1537 times)
Offline liver
« on: July 25, 2010, 01:14:12 pm »
how do youremove the retainer clips on r32 brakes?
ive tried searching but cnt find anything.
Also how do you you split the caliper from the carrier
cheers for the help in advance
Offline edd666999
  • -Receive: 89
Re: how to remove retainer clips?
« Reply #1 on: July 25, 2010, 01:26:55 pm »
its a lift and pull motion. if you concentrate on the center of the retainer you can see it needs to be lifed before you can remove it.
one part just slides out once you have removed the brake pads, if you want to remove the blue bit from the metal bit theres some screws you have to take out.
i tried to be as vague as possible to keep you guessing  :grin:
Offline liver
« Reply #2 on: July 25, 2010, 06:22:40 pm »
not vague at all mate
all done and dusted much appreciated
cheers
