Author Topic: How do you remove this from the dashboard  (Read 9993 times)
Offline CAPTAIN BRITAIN
« on: July 26, 2010, 03:05:44 pm »
How do you remove the phone cradle from the dashboard?
Will it leave a hole in the dash?
Is it worth anything on fleabay?
This is from inside the glovebox.
Offline heavyd
  • -Receive: 29
Re: How do you remove this from the dashboard
« Reply #1 on: July 26, 2010, 03:32:56 pm »
I was wondering the same thing, got an iphone 3gs, so cant buy a cradle, and already bought the bluetooth toch thing, that didnt work either.
Seems like its a new glovebox, about £50 off ebay!
Offline S2 Ant
  • -Receive: 21
« Reply #2 on: July 26, 2010, 03:38:53 pm »
Assuming i understand what you mean and you want to be able to remove that phone kit and not have a hole left behind in the dash then you can buy the part of the dash thats had the hole put in to replace that piece so its tidy - which is what i've done, i just havent fit it yet. Cost me about £26 thru my mate at TPS.
Its a huge piece of the dash you get tho, i'll find a pic and part number later if you like
Ant
« Reply #3 on: July 26, 2010, 03:46:29 pm »
That's right, i just want to get rid of it with no sign that it was fitted,
I still need to know how to remove the thing.
If you could get that part number i'd be grateful.
Offline S2 Ant
  • -Receive: 21
« Reply #4 on: July 26, 2010, 04:06:49 pm »
No worries, i'll post it up when i get home just before 6.
As for fitting it - it looks like it might be fun which is why its still sat in my 2nd bedroom waiting to go on the car lol
Ant
Offline ub7rm
  • -Given: 35
  • -Receive: 43
« Reply #5 on: July 26, 2010, 04:18:54 pm »
That whole lower section from just above the ali stip is the glovebox housing and is actually pretty easy to pull out.  :chicken:
Sepang Blue S4 BE Avant
« Reply #6 on: July 26, 2010, 04:28:27 pm »
You say "pull out" is it not screwed in then?
Offline S2 Ant
  • -Receive: 21
« Reply #7 on: July 26, 2010, 04:48:16 pm »
Yes its screwed in - the ally dash trim looks like it clips on to that lower piece and you'd need to remove the glovebox itself first as it fixes to it
Ant
Offline Norbreck21a
« Reply #8 on: July 26, 2010, 04:56:36 pm »
This is all I was able to find in Elsawin. Not sure if it helps any ?
Andrew
Offline mortygttdi
  • -Receive: 146
« Reply #9 on: July 26, 2010, 05:09:48 pm »
You need to change the full glovebox has that is what the phone holder is sitting on, once you take the holder off you will be left with 4 holes.
If you get one of these dent master type of blokes they maybe able to make it look good,  but seen has a second hand fleebay glovebox will be less than one of the dent guys you may aswell just buy a glovebox and replace it.
Darren
« Reply #10 on: July 26, 2010, 05:19:52 pm »
Thanks for the diagrams Norbreck21a
mortygttdi, Would the replacement piece of trim not be cheaper to buy?
Offline ub7rm
  • -Given: 35
  • -Receive: 43
« Reply #11 on: July 26, 2010, 06:26:24 pm »
Yes sorry there are 7 screws holding it in, see about half way through this guide for removing it.  It looks daunting but its actually pretty straightforward.
http://forums.vwvortex.com/showthread.php?3604801#post44436981
There is much more in this guide than what you need ...
Offline Scotsman
  • -Given: 32
« Reply #12 on: July 26, 2010, 06:33:44 pm »
Interesting thread  :happy2:
I've got the same issue/problem and want rid of mine as well.
« Reply #13 on: July 26, 2010, 06:35:54 pm »
Thanks mate  :happy2:
Offline mb
  • -Receive: 29
« Reply #14 on: July 26, 2010, 09:00:03 pm »
I've removed this from my car.
As stated previously, you will need a new glovebox.  It is also quite easy to change.
