Author Topic: Which Can Bus Gateway  (Read 3354 times)
Offline coop
« on: July 27, 2010, 01:28:33 pm »
Hi Guys
Ive got a version C RNS510 on its way to me can anyone tell me which version Can Bus I need, Ive seen this one on eBay
[ebay]http://cgi.ebay.co.uk/VW-GOLF-MK5-CAN-BUS-GATEWAY-1K0907530F-/200500294108?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2eaebfb1dc#ht_500wt_1154[/ebay]
Not sure if its the correct one and cant seem to find one anywhere else?
Also how can I tell if my can bus even needs upgrading? I'm just assuming it does as I have a June07 GTi?
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: Which Can Bus Gateway
« Reply #1 on: July 27, 2010, 01:32:40 pm »
This is the one you want
Can Gateway Clicky
If you have a K Revison gateway or above then no.
Some people say L revision but i have a K Revision and have no Battery Drain problems. My Car is a Mar 2007 car so yours should be the same or higher BUT you need to check with VCDS as the Car may be a late 06 model that was only registered on June 07
Offline coop
« Reply #2 on: July 27, 2010, 08:37:10 pm »
Thanks Carl
I followed your advice and checked which version I have, Ive got the 1K0907530 k do you think this will be ok with my RNS 510 Version C?
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #3 on: July 27, 2010, 08:40:22 pm »
It should be. But I cant say 100% yes.
Only one way to find out  :signLOL:
If it does drain at least you know it's only £85 to fix  :smiley:
Offline coop
« Reply #4 on: July 27, 2010, 09:04:26 pm »
Cheers, After doing a bit more research I think it should be Ok. If i do have the drain issue how can I tell before I get a flat battery, is it just a case of the stereo dosent turn off when I turn the car off.
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #5 on: July 27, 2010, 09:11:19 pm »
No if your lucky you may find the car struggles to start but does.
If your battery is in good condition it will take 2 - 3 days.
The reason i know a K is ok is i have an A revision that is on 2724 firmware (i have an Octavia vRS) and when i went away on honeymoon it was left for nearly 4 weeks and it started first time.
BUT i can't say if for some reason the LED version drains the battery as i haven't tried one.
If it does i'll swap you My A version for your C version free of charge  :wink: :laugh:
