Author Topic: Spark plug tool  (Read 16403 times)
Spark plug tool
« on: July 28, 2010, 04:38:24 pm »
What size socket do I need to get the old sparkies out? Need to get a sparky removal tool.
Re: Spark plug tool
« Reply #1 on: July 28, 2010, 05:08:38 pm »
Never mind. Found out. Spark plugs are 10mm which is 16mm when referring to standard socket size  :stupid:
Hence need a 10mm spark plug socket. Which genius thought this up?
Offline Mandy
  • -Given: 95
  • -Receive: 94
Re: Spark plug tool
« Reply #2 on: July 28, 2010, 05:21:09 pm »
I was gonna say 10mm but didn't want to look silly if I got it wrong  :ashamed:, (don't ask me how I knew that)
Glad you got it sussed  :smiley:
Saint Steve
Re: Spark plug tool
« Reply #3 on: July 28, 2010, 05:22:46 pm »
good shout Mandy  :surprised:
Offline PDT
  • -Receive: 142
Re: Spark plug tool
« Reply #4 on: July 28, 2010, 07:09:22 pm »
a 10mm spark plug socket has a 16mm hex size. I believe that the 10mm relates to the diameter of the ceramic element of the plug as most plug sockets have a rubber insert that is just smaller then 10mm internal diameter so it grabs the socket to allow it to be removed from the plug 'hole' easily. Another useless fact is that a 16mm spark plug will have a 14mm thread with a metric 1.25mm pitch.
some tips: when removing the plug its always easier to do on a hot engine than a cold one.  Re-installing the plug: push the plug into the socket and then into the trhread, turn counter clockwise by HAND until you feel a click this means that the 2 threads are aligned and will tighten in without cross threading. Tighten the plug by hand and then torque up tight, release the plug and then tighten with a torque wrench. This crushes the compression washer and then retightens it to the right torque meaning that the plugs wont be lower than the desired torque once they heat up.
Bored yet? I could go on.....
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
Re: Spark plug tool
« Reply #5 on: July 28, 2010, 07:30:54 pm »
How do you tighten by hand on the TFSi as they sit at the bottom of the Coilpack holes  :confused:
Re: Spark plug tool
« Reply #6 on: July 28, 2010, 07:58:40 pm »
Awesome info PDT. More is definitely welcome.
What about the use of anti-seize?
Offline nc35
  • -Given: 40
Re: Spark plug tool
« Reply #7 on: July 28, 2010, 08:56:51 pm »
Bump.
I am very interested too.
Just to clarify. You nip up the plug with a normal socket and wrench. Then slacken off before using a Torque wrench.
Also what is the correct torque?
And what about anti sieze?
No Golf anymore.
Enjoyed the last five years of ownership of Mk5 & 6 GTIs.
Plus an excellent forum for knowledge and new ways to deplete the bank account.
Thank You Everyone.
Re: Spark plug tool
« Reply #8 on: July 28, 2010, 10:42:51 pm »
Think the torque is 20-21Nm.
Offline SeanyK
  • -Given: 35
Re: Spark plug tool
« Reply #9 on: July 29, 2010, 12:10:00 am »
I use a Draper spark plug removal tool, it's excellent and if I remember only a few quid...
Here it is;
http://www.tooltrolley.co.uk/product_info.php?products_id=31882&manufacturers_id=268&osCsid=18be283a5e846dc058b5fe72d1fbcf59
Anyhow, all you do, is simply push that into the hole, it locks into place on top of the spark plug, then twist it to loosen, keep turning and then pull gently upwards... The spark plug will then come out with the tool :)
Fitting is a reverse of the above, do NOT overtighten, all you need to do is tighten it just enough - basically, so that you wouldn't need to wrestle with the wrench tool to remove it next time... Turn it until it is very tight - just not over-tight.
It's very easy to do, but very satisfying fitting new plugs - I did mine last week.
Re: Spark plug tool
« Reply #10 on: July 29, 2010, 06:50:45 am »
^^^Halfrauds do the same one, which I was thinking of buying.
Offline Jaywoo-GTI
  • -Given: 38
Re: Spark plug tool
« Reply #11 on: July 29, 2010, 09:24:12 am »
The halfords one works perfectly, spot on lenth to get to the plugs.
Offline icenutter
Re: Spark plug tool
« Reply #12 on: July 29, 2010, 09:26:06 am »
Put it inside the socket then turn that with your fingers.
Get all your sports nutrition products here; http://www.myprotein.co.uk and use the code MP73153 to get 5% off your first order.
Offline nc35
  • -Given: 40
Re: Spark plug tool
« Reply #13 on: July 29, 2010, 10:13:12 am »
Here it is;
Never in 30 yrs torqued up spark plugs, you certainly can't with a tool like this ^^^
Always used a socket set.
Any more comments on anti sieze / copper grease for the plugs before they go back in?
No Golf anymore.
Thank You Everyone.
Re: Spark plug tool
« Reply #14 on: July 29, 2010, 10:44:31 am »
Quote from: nc35 link=topic=17442.msg249562#msg249562
+1. I bought both the spark plug socket and the T-bar socket tool. Also bought some anti-seize copperslip grease too.
