Author Topic: AGGGHHHHHH! Airbag Light  (Read 31715 times)
Offline bigbo
« on: July 28, 2010, 07:43:39 pm »
its just decided to turn itself on for no reason at all. is there any way i can turn it off or will it need a trip to the dealers  :confused:
Offline 182_blue
  • -Receive: 54
Re: AGGGHHHHHH! Airbag Light
« Reply #1 on: July 28, 2010, 07:50:24 pm »
no reason at all ?, have you had anything in bits ?, it can be turned off with VCDS , but i would be worried if it went off by itself and it should really be checked out
Offline winrya
« Reply #2 on: July 28, 2010, 07:53:33 pm »
Happened to me recently.  was just the cable getting pulled sliding the seat forward to get passengers in the back.  Quick reset from a mate with the kit and all is good again
Offline bigbo
« Reply #3 on: July 28, 2010, 08:14:04 pm »
it had been in the garage to have some body work done, unless they did something or disconnected something so dunno. just want it sorting
Offline 182_blue
  • -Receive: 54
« Reply #4 on: July 28, 2010, 08:35:23 pm »
where are you based
Nasir
« Reply #5 on: July 28, 2010, 09:25:59 pm »
My mate just had this on his GTI, it was the wiring under the drivers airbag. The fault was cleared but it came back so a VW specialist re-wired it from the bottom. Cost £40 and apparently quite common on all cars.
Offline bigbo
« Reply #6 on: July 29, 2010, 08:57:19 am »
sheffield
Offline 182_blue
  • -Receive: 54
« Reply #7 on: July 29, 2010, 09:00:47 am »
sheffield
see if anyone near you has VCDS   http://www.mk5golfgti.co.uk/forum/index.php/topic,120.0.html
you can come down to me but im in nottingham
« Reply #8 on: July 29, 2010, 09:20:30 am »
I'm assuming the airbag light stays on after the initial checks have been done on ignition. If so, it's a problem which your VW dealer would best sort out if it persists after a friend with VCDS has had a look. You don't want faulty airbags.
If the airbag light extinguishes after the initial checks, it suggests merely a faulty connection.
« Last Edit: July 29, 2010, 09:22:14 am by RedRobin »
Offline alastairc
« Reply #9 on: July 29, 2010, 05:01:26 pm »
Same here - mine was the side seat air bag on the drivers side - and i have 4 doors so it can only have been minor movements that kept breaking it!
the connector kept breaking - eventually dealer hard-wired it BUT it still happened again - eventually had seat out completely and rewired. it has not re-occurred since.
-  if I am not wrong you want to get it fixed properly as none of the air bags work if one has a fault!
Mk5 GTI DSG, Stage 2 Bluefin, Revo DSG Remap, Miltek Stainless Turbo back with Race cat, Forge Twintercooler, Carbonio Intake, Upgraded Disks and Green Stuff Pads, Konzept Open Fogs, Upgraded OEM Divertor, Leather, SatNav.
« Reply #10 on: July 29, 2010, 05:09:44 pm »
....I'm fairly sure you're wrong. My Recaro Sports seats don't have airbags, so the startup system checks temporarily flag an airbag disconnection. But my VW dealer looked into it and tells me that there's only a problem if the check light remains on. However, I'm not about to intentionally crash the car to find out.
Offline alastairc
« Reply #11 on: July 29, 2010, 05:21:06 pm »
My warning light was staying on that was the problem.....
Offline x5pea
« Reply #12 on: July 29, 2010, 05:24:38 pm »
I've removed various air bags ect, if one is inactive the rest will still deploy in the event of an accident they are independent of each other.
If you code one out or switch it off in vag com the start up checks will still notify the driver each and everytime but the light should distinguish. If the light stays on then one of the circuits have a break, so there are various way to troubleshoot it with a meter or simply a bit of wire but the easiest route is to get someone with VAG com to plug in and see which on it is.
check the connectors under each seat as they are the most common ones to develop a fault, the rest are all covered up behind the dash, carpets. door panels etc
