Author Topic: Climate control on rns-510?  (Read 11985 times)
Offline Gtiain
« on: July 28, 2010, 08:49:23 pm »
Hi guys. I've seen pics of the rns-510 with pictures of seats on and what look like climate controls? How do you get this on?
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: Climate control on rns-510?
« Reply #1 on: July 28, 2010, 08:50:11 pm »
You need the latest Climate Control panel from a MK6 Golf or new Passat etc :happy2:
cameluk
« Reply #2 on: July 28, 2010, 08:54:32 pm »
And mods to the climate control motors, central electrics and possibly add the air quality sensor  :scared:
Offline Gtiain
« Reply #3 on: July 28, 2010, 08:57:54 pm »
Right I see that sounds like a lot of effort! Just out of interest can this panel be retro-fit on a mk5?
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #4 on: July 28, 2010, 09:00:53 pm »
It's a straight swap of the panel but you need Dual Zone to start with
If not and you have the normal Climatic Air Con your looking at over £4k for a conversion as this is what you would need:
New Compressor to take into account the difference in fan speed
New Fans - yours has 4 speed and the dual zone is about 9 from memory
New Wiring Loom - To control everything
New Control Unit - on the dash.
New AirCon Control Module - to account for differences
New Vents - Yours are controlled by cable and the Dual Zone are motorised
New Air Quality Sensor - You have a diff one installed
Then labour on top which would be a long time as the whole dash needs to come out
All very expensive
Offline Gtiain
« Reply #5 on: July 28, 2010, 09:43:03 pm »
4k!!! Wow. I have got dual climate control but that is an incredible amount. Thanks.
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #6 on: July 28, 2010, 10:09:54 pm »
If you already have Dual Zone then it's about £160 on eBay for the dash panel and thats all you need  :happy2:
Offline Gtiain
« Reply #7 on: July 28, 2010, 10:21:24 pm »
That figure might be a bit more realistic! I can't get over that figure of 4k! Thanks.
Offline golfman
  • -Given: 17
« Reply #8 on: July 28, 2010, 10:42:57 pm »
Ive been wanting to do this for ages but just dont know whats involved!!!
carl are you sure its just £160?what parts are required?
scott
Vag-com Hex+Can in scotland
I Hate Timewasters...
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #9 on: July 28, 2010, 11:16:48 pm »
You need Dual Zone Climate control in the car already. If you don't have this then it is too costly to do.
Then you need this panel
Which is from the Passat CC. You may also need a new Central Elec Control Module BUT i'm fairly certain everything needed is contained within the panel.
I know of a couple of people who have done this but it has been in Octavia's. One of those panels was on eBay recently for £160
Part no. is 5K0 907 044 BD ZJU which is for a Satin Black one. From a dealer they are around the £300 mark.
You may also need a new Can-Gateway depending on your car as the earliest anyone i know to have this working is at least an S revision
You will also need a new MFD3 Surround or you could do this (which incidentally is on a MK5 2007 Golf)
You may find 5K0 907 044 AK ZJU versions on Ebay in which the only difference is a slight change on heater buttons
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #10 on: July 29, 2010, 08:02:29 am »
You'd definitely need the new fascia panel, that chopped up one looks naff.
Stu...
Offline 182_blue
  • -Receive: 54
« Reply #11 on: July 29, 2010, 08:40:26 am »
It is a trick feature but im not sure its worth the hassle for getting pic on screen alone, although the switches do look better too
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #12 on: July 29, 2010, 09:32:58 am »
The surrond from the current Jetta is designed for the new aircon controls and the MK5 dash, so you should be able to get hold of one of those parts, last time I looked at this the consensus seemed to be that you would need to convert the whole system over to the BAP protocol, is this not the case?
http://www.mk5golfgti.co.uk/forum/index.php/topic,13273.0.html
Offline xxx_mojo_xxx
  • MUBster DUBster
« Reply #13 on: July 29, 2010, 10:57:37 am »
 :popcornsoda:
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #14 on: July 29, 2010, 11:31:00 am »
 :popcornsoda:
Over the top mod list ;o)
