Author Topic: RNS 510 Coding  (Read 2690 times)
Offline coop
RNS 510 Coding
« on: July 28, 2010, 09:56:22 pm »
Hi Guys
i'm just about to install my rns 510 and was wondering do I defiantly need to code the unit and if so what do I need to buy and do?
Offline 182_blue
  • -Receive: 54
Re: RNS 510 Coding
« Reply #1 on: July 28, 2010, 09:59:45 pm »
Hi Guys
It depends on what the rns was programmed to do before you got it, I think most bits will work fine, but you might not get directions on the highline (if you have it), there will be errors when it's read via vcds etc but they don't affect the performance
Offline coop
Re: RNS 510 Coding
« Reply #2 on: July 28, 2010, 10:16:12 pm »
Dont know if I have the highline or not, ive got a display which displays the dsg status and trip info.
Offline 182_blue
  • -Receive: 54
Re: RNS 510 Coding
« Reply #3 on: July 28, 2010, 10:18:09 pm »
Is it about 3" high ?, and not half plastic, I.e full display
Offline coop
Re: RNS 510 Coding
« Reply #4 on: July 28, 2010, 10:37:27 pm »
Half plastic, bugger.
Re: RNS 510 Coding
« Reply #5 on: July 29, 2010, 11:18:27 am »
Coop could you please post your threads in the relevent section, to save me moving them each day. Cheers.  :drinking:
Offline ady-gti
Re: RNS 510 Coding
« Reply #6 on: July 29, 2010, 01:41:19 pm »
One thing I found with mine was that Bap protocol was enabled, should be for a mk6 but not for mk5. So when I used VCDS it gave lots of errors to do with intermittent communication problems with the DSG buttons on the stearing wheel etc.. I turned it off and all it well.
Offline coop
Re: RNS 510 Coding
« Reply #7 on: July 29, 2010, 07:41:18 pm »
Sorry Top Cat, new to forums, where should I be posting my noob rns questions? Cheers
Offline mortygttdi
  • -Receive: 146
Re: RNS 510 Coding
« Reply #8 on: July 29, 2010, 07:50:06 pm »
Coop it needs posting in the satnav and audio section mate :wink:
