Author Topic: RNS 510 connection to mobile phone  (Read 29511 times)
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: RNS 510 connection to mobile phone
« Reply #30 on: July 31, 2010, 08:44:20 pm »
The details on my website for the Octavia install are quite similar to the Golf, the under seat mounting is the same.
http://www.octavia-vrs.com/technical/bluetooth.html
Stu...
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #31 on: August 01, 2010, 07:10:28 am »
That's not quite everything you need.
It's worth ordering these to -
1Z0 971 813 62U - Covering Black or 1Z0 971 813 3AU Covering Ivory
N909 460 01 - Expanding Nut x2
N908 170 03 - Torx Screw x2
6U0 819 055 - Clip x2
There is also the bracket, I'll get the number for you in a bit.
The bracket is 1Z0 035 185  :happy2:
Stu...
« Reply #32 on: August 01, 2010, 02:11:35 pm »
I would like to try the 7P6 kit in a mk5 as that would be a great solution  :happy2:
 :wink:
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #33 on: August 01, 2010, 02:34:51 pm »
So when is Mr F going to service you with the required module then Ian  :party:
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #34 on: August 01, 2010, 02:46:14 pm »
The deed is done.  :happy2:
Sadly doesn't support the red DiS and VCDS doesn't support it yet.
Stu...
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #35 on: August 01, 2010, 02:57:48 pm »
That's a shame about the red dis :sad1:
Did you enable bap and if so did this stop the normal RNS stuff from showing?
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #36 on: August 01, 2010, 03:00:59 pm »
Bap was left enabled for now but as we didn't have a label file for vcds we're a bit blind. I'll give seb a shout at RT and see what they know.
Stu...
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #37 on: August 01, 2010, 03:55:38 pm »
The label file would be very handy as mine is in US English so would be nice to get that sorted  :happy2:
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #38 on: August 01, 2010, 04:15:08 pm »
If i get anything I'll let you know.
I was under the impression you could change voice via the highline if you are white dash??
Stu...
Offline mortygttdi
  • -Receive: 146
« Reply #39 on: August 01, 2010, 09:49:00 pm »
I was just going to say the 7P6-C unit does not do Red dot display, it actually locks it up it got stuck in the navigation until I changed back to my prem module.
I thought VW had actually got something right for once but no they just made it worse for us guys who have the older VW's
Darren
« Reply #40 on: August 03, 2010, 09:53:58 am »
The A2DP stuff works but only seems to come out the right side speakers.
Not fussed really as its a bit of a gimmick but still a nice to have. Maybe coding will help.
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #41 on: August 03, 2010, 11:32:02 am »
^^^ That will be the loom, it will need the following Pin connecting that aren't normally present  :happy2:
Bluetooth module  Pin 5 - RNS Green Connector Pin 5
Bluetooth module  Pin 4 - RNS Green Connector Pin 11
« Reply #42 on: August 03, 2010, 11:34:06 am »
Bummer  :sad1:
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #43 on: August 03, 2010, 11:37:15 am »
It's only two repair wires and a bit of two core shielded cable  :happy2:
The repair wires you need are: -
1 x 000 979 009
1 x 000 979 010
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #44 on: August 03, 2010, 11:46:14 am »
Ahh of course, the BT device is wired for one side only isn't it.  On the Green plug, Yellow & Blue wires IIRC.
Stu...
