Author Topic: RNS 510 1300 Firmware  (Read 20277 times)
Offline micaerin
  • -Given: 19
Re: RNS 510 1300 Firmware
« Reply #15 on: August 03, 2010, 06:31:41 pm »
Yeah Cheers Norbreck thanks for being our guinea pig LOL
did you just put the disc in and it ran automatically?
2007 GTI DSG, Xenon's, Armrest 6 Disc ,Rear Parking Sensors,Sunroof,Lux Pack,Cruise,Electric drivers seat,MFSW,RNS 510,Miltek Cat Back.
Offline Norbreck21a
« Reply #16 on: August 03, 2010, 07:05:11 pm »
Yep, took about 40 minutes and worked flawlessly.
Rich, when I started the car again tonight, the MDI (Ipod) carried on exactly where I had left off (about 2/3's of the way through the track I was listening to at lunchtime). To be fair I haven't tried it with the HDD files or the SD card but I will over the next couple of days.
Also noticed that before the upgrade, the RNS screen used to call the MDI button "Media IN", whereas now it's called just "MDI". Works perfectly though.
Definatley no Resenberg syndrome either (with my equipment at least)
Here's hoping that the battery issues are indeed sorted, guess I'll find out over the weekend  :surprised:
Andrew
« Last Edit: August 03, 2010, 07:09:24 pm by Norbreck21a »
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #17 on: August 03, 2010, 10:06:38 pm »
So its looking good then, I have downloaded the firmware and have the cd's ready for thursday when I will have a go.
Cheers Andrew  :congrats:
Offline Norbreck21a
« Reply #18 on: August 04, 2010, 07:59:55 am »
Right then a quick update on the 1300 firmware after having a play around with it last night.
Changed
Speed displays operational on the Nav screen (i.e it tells you the max speed for the road you are travelling on).
Ability to set blocked roads on the Navi
Quicker response time to touchscreen presses.
If clock is set to display (in setup menu), then with the ignition on and the RNS switched off, it will display the time.
Ability (on my unit anyway) to use 16GB SDHC cards (didn't have anything bigger)
"MEDIA IN" button on RNS now changed to "MDI"
Showing the HDD capacity now shows a rather nice Pie Chart rather than the single coloured line from before.
Not changed
Still only 4 digit postcode I'm afraid  :confused:
No issues that I can see with MP3 files not starting where left off. tried it with MDI, HDD and SD card and they all work fine.
No Resenberg Syndrome. Picked up my position immediately.
Start-up time not changed (i.e. a tad slow) but as mentioned, when booted, touch screen operation does seem faster (although this could be a placebo effect ?).
So far (at least - no issues with battery drain, although to be fair the car was only left overnight. However upon starting this morning, I did get the "Welcome to VW Navigation" boot screen, which seems to indicate to me that the unit had fully shut down. Took about 15-20 Seconds to fully boot up (i. e until the map screen could be displayed and the "system starting" colourful screen disappeared.
Also, as mentioned, both the music files on the Navi unit and the Maps, plus all settings (Radio presets, bass, treble settings, and colour scheme) were unaffected by the firmware upgrade.
If I find anything more, I'll post up.
Andrew
« Last Edit: August 04, 2010, 08:04:05 am by Norbreck21a »
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #19 on: August 04, 2010, 08:04:30 am »
Postcode's is NOT a firmware issue. It's a mapping issue.
VAG Have to license the 7 Digit functionality and then incorporate that into the mapping. There has been talk for a while now about 7 Digit postcode entry but unless it appears with V7 maps then we will just have to wait until VAG license it :happy2:
Good to see though that 1300 is pretty much the same as the 272X & 276X firmwares :happy2:
Offline Norbreck21a
« Reply #20 on: August 04, 2010, 08:16:53 am »
Ahh, thanks for clearing that up Carl.
Thought to myself, couldn't have the Rev "C" boys having it and not me  :grin:
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #21 on: August 04, 2010, 08:39:32 am »
Cheers Andrew, In my head then I read right time for a sick rep.....  A la top gear  :signLOL:
All sounds very positive, I will go through the procedure myself on Thursday and post up how it gets on with the Skoda Bluetooth and my phone!
Offline Norbreck21a
« Reply #22 on: August 04, 2010, 08:59:22 am »
Yeah, that would be useful Rich  :happy2:
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #23 on: August 04, 2010, 09:04:29 am »
Just been reading your post on the RNS bluetooth thread, will let you know how compatible the new firmware is with the Skoda unit before you splash out on a new setup, I also have the voice control loom in place so I will check if that will work with the updated firmware, as that could be a big bonus especially if it lets me make and answer calls.  Then you dont need a button  :laugh:
Offline Norbreck21a
« Reply #24 on: August 04, 2010, 09:31:57 am »
Top banana  :happy2:
Offline micaerin
  • -Given: 19
« Reply #25 on: August 05, 2010, 06:28:22 pm »
well Installed 1300 on my Ver B unit and alls working great :happy2:
Offline micaerin
  • -Given: 19
« Reply #26 on: August 17, 2010, 12:12:00 pm »
i spoke too soon left car overnight, no longer than usuall and when i went to get in the car today, it has a flat battery!!!
looks like ill have to put 1100 back on it :sad1:
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #27 on: August 17, 2010, 12:29:04 pm »
Just download 2720 or 2760 with the Battery fix :happy2:
Offline Norbreck21a
« Reply #28 on: August 17, 2010, 05:55:22 pm »
that's very strange. I've left mine for 5 days whilst I was away on business, and it started first time on my return. No labouring, just fired instantly and started straight away .
Offline micaerin
  • -Given: 19
« Reply #29 on: August 17, 2010, 06:21:51 pm »
it came out of the blue for me too id left the car for longer with no problems, last used the car about 4pm yesterday went to get in the car at 12pm today and it was completely dead. i hadn't left lights on or anything obvious.
