Author Topic: Urgent help needed! ED30 wheel on a 05 GTI - is it ok?  (Read 5548 times)
Offline SeanyK
  • -Given: 35
« on: August 02, 2010, 03:41:22 pm »
Hey folks,
Sorry to be over-dramatic with the title.
I have been offered an ED30 steering wheel, which has DSG paddles and volume controls etc
If I make sure I have the correct slip ring & Steering control module, would I be right in assuming it is OK to make the paddle shift work and MFSW options work?
It's going in on Friday for big service / cruise control fitting, so figured whilst they had the wheel off, why not stick another one back on and code it there and then.
VW dealer just told me they THINK it should be OK, but wondered if the paddles may not code as it's off a newish ED30 (2008) - but surely if I provide the correct SCM (CH version) that would be ok?
It's just mine is an older GTI (2005) I just wanted to be sure,
Many thanks in advance,
Sean
Offline Richn83
  • -Given: 49
  • -Receive: 85
Re: Urgent help needed! ED30 wheel on a 05 GTI - is it ok?
« Reply #1 on: August 02, 2010, 03:56:53 pm »
I think the only difference will be the red stitching!  :signLOL:
The paddles are just switches, and I have added the post 2006 buttons to my 2005 GTI wheel (mine came off of a Passat R36) and they work fine with the original modules.
Offline SeanyK
  • -Given: 35
« Reply #2 on: August 02, 2010, 03:57:39 pm »
You sir, are a gent!
Thanks man, means I can get the parts ordered in advance ready - will let you know how I get on! :)
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
« Reply #3 on: August 02, 2010, 05:07:52 pm »
I've a brand new boxed steering control module 1PO959542 here, 71.46 + vat from the stealer. Drop me a line if you want it for £40 inc p&p.
Offline wingnutLP
« Reply #4 on: August 02, 2010, 05:24:11 pm »
How much is the cruise control costing you? If you don't mind me asking that is!
Can it be retrofitted to any mk5?
Offline Cooper
« Reply #5 on: August 02, 2010, 05:27:57 pm »
Think so and I think I'm right in saying it's a standard price of £155 from any dealer for parts and fitting
C63
SQ5
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
« Reply #6 on: August 02, 2010, 05:31:18 pm »
Had it retro fitted to my '08 DSG GTI no bother.
Offline SeanyK
  • -Given: 35
« Reply #7 on: August 02, 2010, 05:34:01 pm »
£155 all in... Although they will no doubt say I need an extra wire... But all in should mean all in! :)
Offline SeanyK
  • -Given: 35
« Reply #8 on: August 03, 2010, 12:49:24 am »
Hey guys, which airbag connector do I need?
Single purple wire airbag connector : VW# 1k0 971 584 c
Or
Dual wire harness with multifunction harness: VW# 1k0 971 584 L
I will be re-using the airbag from my existing wheel.
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #9 on: August 03, 2010, 09:06:10 am »
I believe you want the second of the two although I dont know the part numbers, a quick google image search on that part number comes up with the right images.
You want one of these  in the picture with one lead from the yellow master connector to the purple airbag connector, and a second lead that goes to the control module inside the steerig wheel.
Offline SeanyK
  • -Given: 35
« Reply #10 on: August 03, 2010, 02:03:39 pm »
Thanks again Rich, you've been a big help with this.
I will order that part from VW as I called a SEAT dealer I usually use and he said it's VW only and doesn't show on his system.
Offline SeanyK
  • -Given: 35
« Reply #11 on: August 03, 2010, 05:30:19 pm »
I've bought a steering control module;
1k0 953 549 AQ
According to ross-tech ;
1K0-953-549-AQ     Type 2     SW 0070     Highline     Yes     1.6
Which should in theory = MFSW & CRUISE Compatability.
Do you think this will work OK? Even if the ED30 wheel is off a 2008 model?
Everyone seems to buy the 'CH' variant of the SCM, but I wonder if that's just because it's new/current version available from VW / and more for MK6 retrofit wheels.
My old one is 1K0-953-549-F     Type 2     SW 0050     Midline     Yes     -     -
So the difference being 'highline = multifunction' but also the SW 0050 on my current vs SW 0070 on the AQ variant. Also LIN version (whatever that is, is 1.6 or AQ and n/a for the F part)
# Slip Rings
    * Type 1: 1K0-959-653 and 1K0-959-653-A
    * Type 2: 1K0-959-653-C and 1K0-959-653-D
# Variants
    * Lowline: No additional Options/Features
    * Midline: Cruise Control, Board Computer
    * Highline: Cruise Control, Board Computer, Multi-Function Steering Wheel
Fingers crossed, and either way, thanks to TonyT for supplying the SCM at a decent price.
I hope my ramblings help others searching for threads similar in the future! :grin:
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #12 on: August 03, 2010, 05:35:47 pm »
Sean
I have the following im my car
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AG    HW: 1K0 953 549 AG
   Component: J0527           634 0070
   Coding: 0012142
   Shop #: WSC 00200 210 69017
   Part No: XXXXXXXXXXX
   Component: E0221           007 0050
No fault code found.
So think your AQ will be newer and so more than suitable, and a quick google search found me the Ross tech wiki and says mine has the same functionality as yours so should all be good!  :happy2:
1K0-953-549-AG    Type 2    SW 0070    Highline    Yes    1.6    -
Offline SeanyK
  • -Given: 35
« Reply #13 on: August 03, 2010, 05:44:37 pm »
Now all I need to worry about is if I have the right slip ring! lol :)
Appreciate that though Rich mate! Looking good I hope!!! :D  :happy2:
Offline kevinm
  • -Receive: 25
  • No. 728
« Reply #14 on: August 03, 2010, 05:52:18 pm »
My Ed30 has the AQ module and i have paddles, MFSW and cruise control :happy2:
