Author Topic: RNS 510 Bluetooth  (Read 14129 times)
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: RNS 510 Bluetooth
« Reply #16 on: August 03, 2010, 11:16:06 pm »
So long as you don't intend to use an IOS4 device.
If I were you I'd go with the 729E over that as you don't have Highline anyway.
Stu...
Offline coop
« Reply #17 on: August 03, 2010, 11:34:33 pm »
Ok I get it, the 729e meets everything I need and the fact it says white only dosent matter as I dont have the highline, right?
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #18 on: August 04, 2010, 07:26:40 am »
Thats correct mate.  :happy2:
Stu...
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
« Reply #19 on: August 04, 2010, 07:43:14 am »
Coop, I'm running the 729E with my RNS510, midline display, and iphone 3GS on IOS4.01. It's tip top. :happy2:
SteveP did my install, no problems. :notworthy:
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #20 on: August 04, 2010, 07:47:23 am »
Will a 729E work with maxidot Stu?
Offline Norbreck21a
« Reply #21 on: August 04, 2010, 07:48:31 am »
Guys, following the thread above, if I got the 729E unit for use with my "B" Rev RNS and Iphone 3GS 4.01, would the fact that I do have highline screw it up. I'm not too bothered in it displaying on the highline screen, but will it cause other issues ?
Will I still be able to use the other highline functions (Audio, Nav etc.) ? Will the MFSW phone buttons control the RNS and switch the screen to the phone screen, or would that be a purely manual operation (i.e pressing the button on the RNS) ?
Andrew
« Reply #22 on: August 04, 2010, 08:00:28 am »
Only white ones. i.e. Mk6 Golf and facelift Octy.
No I used a 729E in mine for a while and it has been used in another MK5 Golf successfully with no problems.
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
« Reply #23 on: August 04, 2010, 08:14:15 am »
Andrew
Andrew, my MFSW buttons don't control the start/finish calls. The * button mutes, the volume buttons work with RNS or call volume, but the phone button does nothing. This is most likely because my buttons were a retrofit, not from factory, as was the 729E.
However, the touch screen and unit buttons on RNS510 are so easy to use with the phone interface. You'll  be using them to select names/numbers drom your phone's memory, so it really isn't any hardship to tap the green phone on the screen to go, red to end. I can control volume from the wheel, I just can't start or end a call from there. Which doesn't faze me at all.
Offline Norbreck21a
« Reply #24 on: August 04, 2010, 08:22:48 am »
Ahh, cheers buddy for the info. Strange that the phone button doesn't do anything. I guess from yuor description you have the later style buttons (with the Star button and Menu button) ?. I have the older style with the 2 phone buttons on the left. One to initiate a call and one to end. I currently use this with a parrot CK3000 Evolution installed into the car, using a CAN harness to integrate with the steering wheel buttons, and it works fine, but as far as the RNS is aware, it just mutes during a call and routes the call through the speakers and that's all. No contacts, or "PHONE" appears on the screen.
It actually works quite well, but I was getting a little tired of the Iphones built in Voice dialling which can be a bit hit and miss, and so was considering the genuine article so to speak.
Andrew
« Last Edit: August 04, 2010, 08:24:44 am by Norbreck21a »
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
« Reply #25 on: August 04, 2010, 08:24:12 am »
Yup, late buttons on an '08 GTI :happy2:
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #26 on: August 04, 2010, 08:56:44 am »
I have the same setup as Lou, with new buttons, RNS but with a 729B  And again the phone button wont answer or hang up calls, I believe its more to do with the different commands between the VW MFSW and the Skoda UHV unit, so you might find it works with the older buttons.
Offline Norbreck21a
« Reply #27 on: August 04, 2010, 09:01:47 am »
....... so you might find it works with the older buttons.
Nah... I'm never that lucky Rich  :grin:
Offline coop
« Reply #28 on: August 04, 2010, 10:18:06 am »
Thanks guys for your help I went for the 729E on ebay, paid £300 inc delivery, no doubt ill need some advice on the install but ill give it ago, my only concern so far is getting around the airbags in the columns, im assuming this isn't going to be a problem. Cheers
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #29 on: August 04, 2010, 10:20:24 am »
That bits fairly easy, just follow stu guide and you'll be fine, the biggest issue is actually feeding the mic cable across the head lining to the central light cluster.  I ended up using some speaker wire and sellotaping this to the mic cable to drag it across.
