Author Topic: RNS 510 Lost Fader Control  (Read 2166 times)
cameluk
« on: August 03, 2010, 08:45:31 pm »
After fitting my Blaupunkt THA 555 PNP amplifier with the PnP harness, I have lost the option under Tone of Balance / Fader with the fancy in-car graphic, I only have balance for left/right
I disabled speaker monitoring in Byte 4 setting it to either 00 Not Coded or 01 Speaker Monitoring InActive as I ended up with a huge list of fault codes as the RNS could no longer detect the speakers being attached due to the Amp I think
Is there any way of being able to control the fade from the RNS between front and rear now that I have an amp  :confused:
