Author Topic: How To and Parts needed for relocating the DV on a K03 car?  (Read 8144 times)
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: How To and Parts needed for relocating the DV on a K03 car?
« Reply #15 on: August 04, 2010, 03:57:31 pm »
Ant I've edited the post as I cocked up, you need the bung in with the OEM DV.
Stu...
Offline S2 Ant
  • -Receive: 21
« Reply #16 on: August 04, 2010, 03:59:45 pm »
Ok cheers for that.
I've put prices down that i've got, i'll have to get my mate to get the rest for me - the prices listed are current retail price.
Ant
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #17 on: August 04, 2010, 05:52:43 pm »
Spot on, thanks for that
So should need the following OEM part numbers i believe....
1K0 145 770 P - Intake pipework from IC to IM (£35.38+VAT)
1K0 145 693 B - Pipe from DV back to Intake pipework (£35.38+VAT)
06F 145 751 - Port connecting the DV to the pipework (
1K0 145 845 A - Hose connecting port piece to the DV and return pipe
With standard intake you'll also need this...
06F 129 627 H - Accordion pipe from Turbo to Inlet pipework - includes return feed for pipe 1K0 145 693 B (£26.30+VAT)
With aftermarket intake you'll need to adapt that pipe to fit whatever port is on it - BSH intake pipe has a 35mm ID port for this feed.
And obviously a bung for the original DV location.
Spot on  :happy2:
Over the top mod list ;o)
Offline S2 Ant
  • -Receive: 21
« Reply #18 on: August 04, 2010, 05:56:55 pm »
Just got home and can see your pics now Danish - couldnt see them from work.
On your plastic pipe from IC to IM, whats the hose you've got on the port you'd put the DV on? Its got a metal cap to it.
I've been basing this on the K04 with part numbers image thats floating around and cant see that pipe on that one.
I assumed its just the short slightly kinked pipe on that image that goes on this port up to the DV bits
Note to self - must sort out ETKA!
Ant
  • -Given: 243
  • -Receive: 154
« Reply #19 on: August 04, 2010, 06:32:31 pm »
you don't need that part, it's for the GTI solution, and is not needed for the S3 solution. I had the GTI solution in a big box filled with GTI engine parts and didn't know what was what so i ordered the S3 and ended up having both  :stupid:  :grin:
Offline 56OctyVRS
  • -Receive: 72
« Reply #20 on: June 25, 2011, 12:01:40 pm »
I would presume these parts will fit the Octy VRS too?  Me thinks my next mod to my car as I will eventually go K04.
Do bsh sell the bung by itself or is there a blanking plate I can buy?  Also what part number is the wiring loom needed to connect the new DV up to the electronics or where can I get one from please?
Offline Sie
« Reply #21 on: June 25, 2011, 09:31:30 pm »
Forge do a blanking plate listed under astra vxr. Or eBay that's where I got mine from about £27.
Awesome too
http://www.awesome-gti.co.uk/product.php?xProd=18867
Sie
Fettled Laser Blue '05 GTi 5dr
