Author Topic: Reverse light  (Read 17760 times)
Offline WYTHIT
Reverse light
« on: August 04, 2010, 06:12:52 pm »
On my golf gti mk5 ive fitted a new reverse light sensor today but my reverse light still wont work :scared:The bulb is fine does the reverse light have its own fuse?
Offline WYTHIT
Re: Reverse light
« Reply #1 on: August 04, 2010, 08:42:31 pm »
has anyboy got a diagram of the fusebox?
Offline WYTHIT
Re: Reverse light
« Reply #2 on: August 05, 2010, 12:23:27 am »
does anybody on here know which fuse is for the reverse light pleeeeeaaaassseeee? :happy2:
Offline Norbreck21a
Re: Reverse light
« Reply #3 on: August 05, 2010, 07:52:38 am »
According to Elsa Win, it's in the fuse panel in the right side of the dash and it's fuse No 4 (15a) but it controls more than just the reverse light.
M17 Reverse Light
J255 Climatronic Control Unit
G65 High Pressure Sender
E16 Heter/Heat Output switch
J530 Garage Door Opener
G128 Seat Occupied Sensor (fornt passenger)
Y7 Anti Dazzle Mirror
E422 TPMS
K216 ESP Warning Lamp
Z20 Left Washer Jet Heater element
Z21 Right washer jet heating element
So considering how much equipment is controlled by this fuse, I think you would know if it was blown ?
Offline WYTHIT
Re: Reverse light
« Reply #4 on: August 05, 2010, 08:12:24 am »
cheers for the reply :happy2:
Ive changed the bulb and reverse light sender im going test the switches and wires today to see if they live
Offline GTI Osprey
Re: Reverse light
« Reply #5 on: July 22, 2012, 11:02:40 pm »
I have a similar issue - so thought I'd resurrect the thread to show I've used the search function! :drinking:
As a reminder my car is a 2005 / 55 plate K03 GTI and the [latest in a long line!] in problems;
* Reversing light has failed and has been flagged on the dashboard.
* I've checked the bulb and its fine!
* Reversing sensors work so I'm assuming the reverse switch works - is this a dangerous assumption? :ashamed:
* The fuse is fine
Please help! I've spent nearly £2k on car in last month and could do without shelling out any-more.
Cheers.
Alex
Offline apples12
Re: Reverse light
« Reply #6 on: July 23, 2012, 12:27:55 am »
You may have just damaged the wire at CECM (central electronics control module) end - I managed this when I was retrofitting my fogs (long story).
Check to see that you've got current going to the wire in the boot lid ....
MK6 GT TDI  - CW - LUX pack
GONE
Offline GTI Osprey
Re: Reverse light
« Reply #7 on: July 24, 2012, 06:51:47 pm »
Will do - thanks.
