Author Topic: How to Relocate K03 DV to K04 Position Tutorial  (Read 39061 times)
Re: How to Relocate K03 DV to K04 Position Tutorial
« Reply #15 on: August 05, 2010, 01:02:18 pm »
Even the Forge DV is a servicable item Robin so for ease of access then yes.
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #16 on: August 05, 2010, 03:57:19 pm »
I had the forge DV before I relocated and had to get a service kit for it
This incorporated a new spring, seals and grease. So as Ian says the relocation is best for servicing needs.
As I said earlier now that the DV design has changed there is no real need until you go to K04.
Offline Aaron_RJ
« Reply #17 on: January 14, 2011, 08:08:05 pm »
You beat me to it Carl with another good how to:)!  Did this 2 nights ago on my vRS and was about to put a tutorial up.  I used the Forge blank for the turbo.  Saves having another DV.  I didnt do the wiring extension (I was too impatient to order the plugs) so I just pulled the wiring back and moved it to the front.  The reason I did this is I will be going K04 soon and the dump noise through the filter is much better!!!
Parts I used:
Forge Blank:
Bung insert for the 25mm take off:
Finished:
do you have the part nos for all the parts please?
2007 GTI | 18'' Monzas |Xenons|Highline|MFSW|Lux pack| Factory Tints |Cruise control
Mods: VWR Quickshift |Forge DV |Autotech HPFP| Sportlines | |Goodrich hoses |Milltek non res TBE | Stage 2 map | Custom CAI
Offline TrickGTI
« Reply #18 on: January 14, 2011, 09:00:46 pm »
Great how to there  :congrats: it's what this forum is all about!!!
2006 Tornado red GTI
Offline vRS_Pagey
  • -Receive: 59
« Reply #19 on: January 21, 2011, 04:27:51 pm »
Carl, is this picture looking up, from under the car?
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #20 on: January 21, 2011, 04:32:17 pm »
Yes mate.
From the drivers side. The big black bar at the bottom of the pic is part of the axle :happy2:
Offline Sie
« Reply #21 on: January 21, 2011, 06:52:51 pm »
Take it you didnt have to untape the loom to pull cables around you just rerouted them??
Brill Tutorial got all the bits just need to do it, wen it gets warmer.
Sie
Fettled Laser Blue '05 GTi 5dr
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #22 on: January 21, 2011, 07:14:22 pm »
Yes mate I just re-routed the extension loom down to the original connector. :happy2:
Offline Sie
« Reply #23 on: January 22, 2011, 02:27:27 pm »
I did see a Thread with some part numbers for the extension loom, is this how you made it??
You dont have the numbers do you??
BDMAlex you send about rerouting the cables is it long enough just to reroute??
Thanks Guys
Sie
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #24 on: January 22, 2011, 05:37:22 pm »
I built the Loom that Carl uses from OEM parts.  Not sure if I've still got the numbers, I'll look.
Stu...
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #25 on: January 22, 2011, 05:49:10 pm »
1J0 973 822 A   2 Pin Brown Flat Contact Housing    1
1J0 973 722 A   2 Pin Black Flat Contact Housing     1
000 979 134   Single Wire 1.0mm                         2
000 979 133   Single Wire 1.0mm                         2
N 107 324 01   Corrugated Pipe 4.5mm (M)            2
N 906 819 01   Corrugated Pipe End Piece 4.5mm    2
Stu...
Offline Sie
« Reply #26 on: January 22, 2011, 09:46:26 pm »
Brill thank you. Did it all cost much?
Sie
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #27 on: January 22, 2011, 09:47:32 pm »
Not an enormous amount, no.
You'll also need some decent cable to make the length.
Stu...
Offline vRSAlex
  • -Receive: 253
« Reply #28 on: January 23, 2011, 12:56:23 pm »
With the wiring on mine and the ones I do at work, you just need to pull with wiring back to the start of the coilpack wirings plastic housing.  That gives the perfect length to route the wiring round the right side of the engine and onto the DV.
Using a wiring extension is faster and easier, but costs more and imo doesnt look as neat/oem.
Follow AKS tuning on Facebook
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #29 on: January 23, 2011, 12:58:46 pm »
Depends how neat & OCD you are  :P
