Author Topic: Engine oil light just came on..  (Read 4959 times)
Offline aidogti
« on: August 04, 2010, 10:12:41 pm »
Hi lads as title says, car was serviced bout 2 months ago, now I got oil in GSF and it was super synthetic long life oil , I have the car nearly 8 months and this is the first time the oil light has come on, it's a 2005 axx Gti, I did read that this is common but is there a better oil to use that the engine won't burn??
Online stealthwolf
  • -Receive: 291
Re: Engine oil light just came on..
« Reply #1 on: August 05, 2010, 12:07:54 am »
Not really. VW acceptable limits are 1l per 600 miles. Just continue to use 5W30 oil approved to 504 standards.
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #2 on: August 05, 2010, 08:35:50 am »
.........mine did the same last week. 05 AXX engine. I pulled straight over & checked the level, just above the min mark. Started engine & no light ? i was only a mile from were i was going so got correct oil & topped up.
Been ok ever since. :happy2:
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #3 on: August 05, 2010, 08:55:11 am »
I have found that my vRS (BWA Engine) seems to use less oil if I fill it to about 3/4 full on the dipstick rather than full.
But in 60k miles I have probably gone through 30ltr of oil. I just use the VAG own quantum stuff. £35 for 5 litre tub from the dealer :happy2:
Offline FamilyDub
  • ...who needs a diesel?
« Reply #4 on: August 05, 2010, 09:45:46 am »
Some cars just seem to be a bit more oily that others and as stated, VW's tolerance is a litre per 1000km, ~621 miles.
My car is well looked after, but I tend to only get 1500-2000 miles between top-ups of oil. That equates to about a litre every 3 months for me, which I think is acceptable.  :happy2:
MKV GTI | Reflex Silver | 5-dr, Family-Spec | 17" w/anthracite Finish | Manual | Highline | Cruise | Revision 'D' DV | Dirty Pipes |
« Reply #5 on: August 05, 2010, 10:28:06 am »
My Ed used about half a litre between each 10k service and the .:R uses nowt.  :smiley:
Having said that though I still check the oil rather than be surprised that the oil light has come on.  :surprised:
« Reply #6 on: August 05, 2010, 10:29:20 am »
cars with a turbo do use oil pure and simple
Offline FamilyDub
« Reply #7 on: August 05, 2010, 10:31:29 am »
^^^ Good practice to get into.  :happy2:
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #8 on: August 05, 2010, 11:37:11 am »
..........must admit i'm very good at this, the day mine came on i had just got off the motorway & a bit of spirited driving  :driver:  :innocent:.Never had it before on any of the cars i've had & when i checked it was just over the min mark ?. I toped it up to 3/4 on the stick & no problems since. :happy2:
« Reply #9 on: August 05, 2010, 11:38:39 am »
check your oil once a week its simple to do just make sure your on a flat surface so the oil in the sump is level
« Reply #10 on: August 05, 2010, 12:01:04 pm »
infact mine runs on castrol rs 0/40
« Last Edit: August 05, 2010, 12:11:18 pm by MAT ED30 »
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #11 on: August 05, 2010, 12:05:58 pm »
I get mine from the dealers it's Castrol but 5w-30. SLF Long Life III.
Offline aidogti
« Reply #12 on: August 05, 2010, 07:52:50 pm »
thanks for the relpies lads, GSF gave me 0w/30 longlife oil... do i have to top up wit tha same grade oil???
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #13 on: August 06, 2010, 09:37:41 am »
............my mate services mine (he's a tech) for VW & always puts this in & this is the 1litre top up he got me the other week. It's a Castrol bottle with a VW badge on it. :happy2:
Offline aidogti
« Reply #14 on: August 06, 2010, 10:44:58 pm »
yeah i got a ltr of castrol 5w30, 18euro... put in bout 2/3's and checked level, its 3/4's of the way between min and max...
thanks again lads for the replies.. i'll be checkin the oil more often now :happy2:
