Author Topic: REVO anti theft??  (Read 6894 times)
Offline illyun
Re: REVO anti theft??
« Reply #15 on: August 06, 2010, 09:31:19 am »
The switch they sell has an anti theft mode, takes a couple of seconds to apply and once applied it disables The throttle pedal and car idles at about 500 rpm
Mine doesn't idle at around 500rpm. when the anti-theft is on... it cuts out after 5 seconds.
Offline S2 Ant
  • -Receive: 21
« Reply #16 on: August 06, 2010, 10:01:17 am »
Last time i tried mine (which was a few weeks ago now as my switch is with Revo at the mo) it just about manages to idle, barely, but then i've never left it running long - just checked the first few times of using that its done the job so i guess it may well die if left long enough.
Ant
« Reply #17 on: August 06, 2010, 11:13:08 pm »
I find you have to sit perfectly still. if you even so much as blink it cuts out.  :laugh:
« Reply #18 on: August 06, 2010, 11:56:44 pm »
So am I right in thinking this anti theft feature isn't connected to the map and each time you use it the map will be taken off and put back on?  :confused:
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #19 on: August 07, 2010, 07:46:57 am »
No all the anti theft does is disable the throttle.
The map is still on the car.
Offline Golfgirl
« Reply #20 on: August 07, 2010, 12:04:39 pm »
Same here.
FOR SALE!
Offline big al
« Reply #21 on: August 07, 2010, 12:34:20 pm »
Where does it plug in?
Offline Golfgirl
« Reply #22 on: August 07, 2010, 12:35:43 pm »
In the ECU port - get on your knees by the drivers door and it's under the dash :happy2:
FOR SALE!
« Reply #23 on: August 07, 2010, 03:48:48 pm »
Once you've located it, you can reach it from the driver's seat. You don't need to get back on your knees again - unless you like that kind of thing!  :grin:
Offline Golfgirl
« Reply #24 on: August 08, 2010, 02:34:03 pm »
 :party:
FOR SALE!
