Author Topic: CW GTi  (Read 15078 times)
Offline big al
Re: CW GTi
« Reply #30 on: December 17, 2010, 05:13:36 pm »
Dont have any further "plans" for the car. Just want to get myself round Nurburgring at some point.
Join the club, thinking May time and convoy it over with the other members off here.
Offline edd666999
  • -Receive: 89
Re: CW GTi
« Reply #31 on: March 21, 2011, 05:00:29 pm »
Well im booked for the ring trip and i went from res exhaust to non res today! cant decide if i like it yet...
Offline edd666999
  • -Receive: 89
Re: CW GTi
« Reply #32 on: November 04, 2011, 09:50:23 pm »
Not updated this for some time!
i kept the NON RES exhaust because the noise was  :evilgrin:
I bought some 17" gti wheels and have wrapped them in some r888's for the ring next year.
Yesterday i went to have my exhaust mount wealded again due to so much engine movement...So i bought:
Had them fitted this morning.
Noise has increased in low rev range, a little too much for my liking but im going to see if they get better after bedding in!
Next up is replace all bushes, some TT wishbones and a intercooler!
Offline edd666999
  • -Receive: 89
Re: CW GTi
« Reply #33 on: November 21, 2011, 05:55:34 am »
Fitted my boost gauge yesterday, impressed with myself  :grin:
Offline Grande_GTi
  • -Given: 41
Re: CW GTi
« Reply #34 on: November 21, 2011, 11:36:58 am »
Oooo white mk5's are so lush
Nice example  :wink:
instgram @ricky_grande
check out @lowlife_official
MK5 GTi OEM+
Offline edd666999
  • -Receive: 89
Re: CW GTi
« Reply #35 on: June 30, 2012, 05:00:56 pm »
fitted a s3 intercooler today. Took 6hours to fit by myself and 2hours of that was during thunder and lightening and i got drenched!
DSG map, FMIC to come soon :)
Offline edd666999
  • -Receive: 89
Re: CW GTi
« Reply #36 on: July 17, 2012, 07:30:41 pm »
Another fairly big update.
Was losing boost quite substantially in the higher rev range, and peak power was 230bhp  :grin: Big thanks to PDT for spending time on my car narrowing down where the issue could be and er...turning my exhaust round the correct way.
I had a smoke test done, which showed boost pipes were fine.
Took the car to PSI tuning in stoke to have the DP taken off and the turbo inspected for a crack. They have taken the intake off and blanked off the DV in search of a loud screech that comes from the car when on boost. Its pointing to the turbo, it could be something as cheap as a gasket or as expensive as the turbo internals, but didnt want to say 100% unless the turbo is off the car.
I have decided to go K04 rather than spending cash taking a turbo off and replacing it with the same thing. PSI has made me an offer i cant refuse regarding going to APR software + Fitting turbo. Two benefits i can see are that it doesn't disappear when disconnecting the battery and i can once again return to Awesome GTI for any map changes.
I never really planned to go K04 when i got the car and has been a hard decision to make as to if its going to be worth it, but with 310-330bhp its means i have a much bigger willy to wave now.
PSI tuning offer APR and CC remaps, APR don't do a DSG map and from what i have read i wouldn't touch a CC map. So i will be hopefully taking the car to Nick @ R tech for his DSG map.
These are the bits im going to purchase:
079 130 757 - RS4 Pressure release valve.
06F 145 751 - S3 Intermediate flange
1K0 145 845 A - pressure hose
1K0 145 693 B - S3 Air Circulation Pipe
06F 145 757 F - gasket for oil pan?
1K0 145 762 BM - pressure pipe
06F 133 073 D - Intake Manifold Gasket
06F 253 039 E - Exhaust Manifold Gasket
N 908 945 01 - 5 x  hex. nut, self-locking - exhaust stud nuts
N 102 861 08 - 4 x shouldered hex. nut, self-locking
N 013 851 4 - 4 x sealing washer These are the copper sealing washers for the oil and coolant lines.
N 910 848 01 - 4 x mounting bolts for the DV into the stock S3 flange
06F 145 383 L - DV Mounting Bracket
1K0 253 115 K - Downpipe gasket
N 044 502 3 - 4 x Downpipe studs
1K0 145 770 P - S3 Air Pipe
« Last Edit: July 17, 2012, 07:35:04 pm by edd666999 »
