Author Topic: Trip computer not accurate  (Read 2164 times)
Offline stu_no_1
« on: August 06, 2010, 02:05:05 pm »
My average mpg on my trip computer is miles out when it says 20mpg its really about 25mpg when i work it out on how many miles i got from so many litres has anybody else got this problem and can it be fixed the funny thing is the miles till empty is quite accurate so i just go by that
Offline big al
Re: Trip computer not accurate
« Reply #1 on: August 06, 2010, 03:11:29 pm »
Have you pressed the reset/ok buton on the bottom of the stalk by accident? On the screen there should be a number 1, if there is a number 2 then it is showing average MPG, etc.
Just press the button once and it should change it back for you.
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #2 on: August 06, 2010, 04:03:43 pm »
The computers are generally a bit in accurate, the speedo itself is generally in the region of 10% out, the computer will also be rounding off figures, and have a sampling rate which will all add in-accuracies there is an ability to add a correction factor in VCDS for the speedo not sure if this would also alter the consumption value.  :happy2:
Offline stu_no_1
« Reply #3 on: August 06, 2010, 07:53:12 pm »
no ive not pressed anything by accident i know how it works it just it always read about 4 or 5 mpg lower than im getting the highest ive ever had was 30mpg but i done nearly 400 miles on the tank this worked out at nearly 40mpg so im thinking its maybe a percentage out as the gap has got bigger as the number it displayed got higher
Offline stu_no_1
« Reply #4 on: August 07, 2010, 08:03:56 am »
anybody help me out with this?
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #5 on: August 07, 2010, 10:07:24 am »
You can accurise the Trip Computer.
Work out the actual MPG figure from a full tank
Number of litres added / 4.54 = number of gallons used
Actual MPG = distance on full tank / gallons used
Go into VCDS/VAGCOM, open controller 17, Instruments
Click advanced functions, Adaptation box 10
Scroll up to channel 3
Standard default value = 100%. This can be altered withing the range 85% to 115%
Work out new value this way:
New % figure = (old % figure x MPG figure shown on dash) / calculated actual MPG figure
I have done both my cars and it's pretty much spot on now  :happy2:
Disclaimer: Neither I nor MK5GolfGTi will be held responsible if anything goes wrong. If you do this procedure you do so at your own risk!
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #6 on: August 07, 2010, 10:29:07 am »
I've added this to the VCDS Tips & Tricks Carl  :happy2:   :notworthy:
http://www.mk5golfgti.co.uk/forum/index.php/topic,121.new.html#new
Stu...
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #7 on: August 07, 2010, 11:42:52 am »
Cheers Stu :happy2:
« Last Edit: August 07, 2010, 07:12:05 pm by vRS Carl »
