Author Topic: RNS 510 GPS Antenna  (Read 10099 times)
Offline coop
RNS 510 GPS Antenna
« on: August 06, 2010, 04:54:55 pm »
Hi Guys
I've just fitted my RNS 510 and have a issue were the sat nav takes around 5 minutes to work out its not in Germany?  The Antenna is sitting straight below the air vent on top of the arm which opens and closes the top vent. Anyone else have this issue, any one recommend an alternative location for the GPS, or maybe I can upgrade the Antenna? Cheers.
Offline 182_blue
  • -Receive: 54
Re: RNS 510 GPS Antenna
« Reply #1 on: August 06, 2010, 05:11:54 pm »
Hi Guys
What model version do you have ?, and what firmware is it running , was the german location Regensburg ?
ps when on map press map again and see how many satellites your getting  :happy2:
Offline coop
« Reply #2 on: August 06, 2010, 05:27:19 pm »
Version C and the latest firmware, yes the town is Regensburg. I get about 5 out of 8 but it takes around 5 minutes to pickup anything.
« Reply #3 on: August 06, 2010, 05:37:31 pm »
Sounds like Resenberg syndrome. Firmware needs sorting out.
Offline ashley
« Reply #4 on: August 06, 2010, 05:40:02 pm »
I have the rev c and the same issue. Seems to default to Germany when loses signal such as in a underground car park or in a built up area. Very annoying if you dont know where your going ! Then takes ages to sort itself out even when finds a signal.
My antenna is in the same spot, so that sounds like the problem.
« Reply #5 on: August 06, 2010, 05:41:47 pm »
It's not the location of the antenna - it's the firmware!
Offline 182_blue
  • -Receive: 54
« Reply #6 on: August 06, 2010, 05:49:39 pm »
Are you sure you have a C version or is it an earlier version with later firmware on it ?
« Last Edit: August 06, 2010, 05:55:43 pm by 182_blue »
Offline coop
« Reply #7 on: August 06, 2010, 06:57:20 pm »
Its a version C unit, well thats what I was told, how can I tell? Its running firmware 2680. It will only show germany if the cars been off for a while if its just off for 30 mins it will show my current location when I turn it back on. Displaying germany while its trying to work out where it is, isnt really an issue, the main problem is it takes so long to track a satellite, having to wait 4 minutes before I can set off is a serious ball ache.
Offline coop
« Reply #8 on: August 06, 2010, 07:08:36 pm »
I think it may be a canbus issue, I'm on a K Revision. But as I say fixing the Regensburg issue I dont think will resolve the main issue of how long it takes to acquire satellites, I may be wrong.
Offline 182_blue
  • -Receive: 54
« Reply #9 on: August 06, 2010, 07:16:45 pm »
where did you get it ?
Offline coop
« Reply #10 on: August 06, 2010, 07:18:43 pm »
ebay, It looked brand new and it does take sdhc cards to im guessing it is ver c.
Offline 182_blue
  • -Receive: 54
« Reply #11 on: August 06, 2010, 07:23:47 pm »
do you have the numbers from the unit, A units with later firmware take sdhc cards by the way
Offline coop
« Reply #12 on: August 06, 2010, 07:28:39 pm »
just checked on the secret menu under version the last letter is C, I would have been surprised if it wasnt a version C as the seller sells a lot of units and has a good rating.
Offline 182_blue
  • -Receive: 54
« Reply #13 on: August 06, 2010, 07:58:00 pm »
My A unit did though after updating firmware, do you have link to the seller ?
Offline coop
