Author Topic: S3 Brakes do they fit........... Fronts yes, rears??  (Read 10209 times)
Offline QD MBE
  • -Receive: 102
« on: January 30, 2009, 08:11:40 pm »
After some searching, I gather that S3 Fronts are R32 with a simple re badge.  But the question is this - Will the rears fit, some say yes, and the only issue being the security of the stone guard, but there is no real firm evidence (that i could find!)
So any firm evidence..........................
Offline cal tdi
  • dub or die
Re: S3 Brakes do they fit........... Fronts yes, rears??
« Reply #1 on: January 30, 2009, 08:31:48 pm »
also same as the leon cupra as well
not exactly firm evidence but some issues were talked about on another thread on here (think it was in the technical)
Candy weiß Mk6 GTI - Stage 2
  • -Receive: 453
« Reply #2 on: January 30, 2009, 08:41:47 pm »
iirc, neg is having the same thoughts about this rear install.
Offline 182_blue
  • -Receive: 54
« Reply #3 on: January 30, 2009, 08:48:06 pm »
TT said they wouldnt fit
The R32 rear brakes will NOT fit the Edition 30, nor any other front wheel drive Golf V platform car.
The R32, and the identical spec S3 rear brakes will ONLY fit a four wheel drive car.  The hubs are different, and the wheel bearings are different.
If you really wanted to put the R32/S3 rear brakes on a GTI/Ed30/Leon Cupra R/Octy vRS - then you will need some serious modification to the rear suspension setup, including:
  • two new rear hubs
  • two new rear wheel bearings
  • two outer CV joint "housing" (to support the rear wheel bearing)
  • two new handbrake cables
  • along with the entire rear brake setup (calipers, caliper carriers, discs, backplates, pads)
Boy, there seems to be some mis-information creeping into this forum!  :rolleyes:
Offline 182_blue
  • -Receive: 54
« Reply #4 on: January 30, 2009, 08:53:03 pm »
Offline QD MBE
  • -Receive: 102
« Reply #5 on: January 30, 2009, 09:10:11 pm »
Hmmmmmmmmmmmmmmmmmmm.............
Might be worth a punt.
Offline QD MBE
  • -Receive: 102
« Reply #6 on: January 31, 2009, 10:28:57 am »
Hmmmmmmmmmmm
a full set of S3 brakes - £450...............  have to collect from Birmingham............
« Reply #7 on: February 01, 2009, 08:19:55 am »
I will be selling my leon cupra 1P (Mk 5 platform) Calipers and discs and pads if theyre any good.  In 6months theyre going
in favour of tarox 10pots or ecs stage 5 ....  :smiley:
hufcforpromotion
« Reply #8 on: February 01, 2009, 09:45:23 am »
I will take them off you mate for the right price!
Cheers John
Offline neg
  • gone old skool
« Reply #9 on: February 01, 2009, 10:11:07 am »
From all the info I have seen and a guy in the states who has done it they sounds like they do fit.  Once I get my set painted I will find out...
  • -Receive: 453
« Reply #10 on: February 01, 2009, 10:14:07 am »
There will be no stopping you if they fit...    :grin:
« Reply #11 on: February 01, 2009, 02:14:35 pm »
On the contrary if they fit he'll be stopping pretty sharpish lol
« Reply #12 on: November 05, 2009, 01:10:28 am »
Having just said yes to buying some S3 rears from DaveB I'm now somewhat concerned to read T_T's post saying (if I understand it correctly) that it's a No-No without additional major work (quoted in Reply #3).
But my understanding is that both stokeballoon and Hurdy have successfully fitted S3 rear brakes without doing what T_T says must be done.
Offline QD MBE
  • -Receive: 102
« Reply #13 on: November 05, 2009, 06:25:35 am »
Robin, T_T was wrong.  The S3's fit spot on.  I had  mine fitted within 2 hours and that was taking pics along the way.
DR
How to
http://www.worldimpex.com//assets/partdocuments/DIY_Rear_310mm_R32-1.pdf
« Reply #14 on: November 05, 2009, 07:19:18 am »
I think the last line in your quote in post 3 sums it up.  :wink:
