Author Topic: fitting Passat switches to Mk5 golf  (Read 56000 times)
Offline muddyfox480
Re: fitting Passat switches to Mk5 golf
« Reply #60 on: September 06, 2013, 06:58:04 pm »
Well done!  That looks a really sweet mod, makes such a difference :)  :happy2:
Offline dandav1985
  • -Given: 17
    • http://www.mk5golfgti.co.uk/forum/index.php/topic,72356.0.html
« Reply #61 on: September 07, 2013, 01:06:20 am »
Hello,
 New the the forum, is there any chance in the VW part numbers? :happy2:
Sorry just read through the tread again seen the link :stupid: I take it I can just go to VW and ask for these at the parts Desk?
Cheers Dan
« Last Edit: September 07, 2013, 03:23:19 am by dandav1985 »
Sprint Blue Audi S3, 8P3 s-tronic, Panoramic Roof.
Stage 2 shark remap, Turbo back Miltek, CTS Turbo intake.....322bhp.
Auto lights, Auto wipers, Dimming-Anti Dazzle folding mirrors, Electric & heated seats, Bi-Xenons, Hill Assist, TPMS, Parking Ad, TV Head rest, RNS-E etc..................
Genuine VCDS (vag com) owner
Offline Simon_2.0t
« Reply #62 on: November 24, 2013, 01:09:11 pm »
Great guide guys  :happy2:
Si
Offline J400uk
  • -Receive: 27
« Reply #63 on: February 28, 2014, 11:59:48 am »
Yep top guide, recently ordered the parts and planning on fitting soon :happy2:
Offline J400uk
  • -Receive: 27
« Reply #64 on: March 16, 2014, 06:54:28 pm »
So my switches turned up earlier this week and I had a go fitting them this weekend. Seem to work fine and certainly look nice, but I'm getting a funny error in VCDS now. Anyone had similar?
                Address 09: Cent. Elect.       Labels: 3C0-937-049-23-H.lbl
Control Module Part Number: 3C0 937 049 E    HW: 3C0 937 049 E
  Component and/or Version: Bordnetz-SG     H37 1002
           Software Coding: E58D0F2700041800001400001400000000087F075C
            Work Shop Code: WSC 00000 785 00200
           Additional Info: 1K2955119C  Wischer VW350  013  0402   1K0955559T  RegenLichtSens 011  1110
                      VCID: 2B55C1518AE29934DCA7C3
1 Fault Found:
01800 - Light Switch (E1)
            008 -- Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 16
                    Mileage: 154802 km
                    Time Indication: 0
             Freeze Frame:
                        OFF
                    Voltage: 12.20 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
Offline doylebros
« Reply #65 on: March 16, 2014, 07:08:08 pm »
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 16
                    Mileage: 154802 km
                    Time Indication: 0
             Freeze Frame:
                        OFF
                    Voltage: 12.20 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
I've cut this from another poster who had the same problem
This could mean a few things,
1. Switch itself is broken, common issue
2. cable isn't connecting or has cut in it.
3a. I pulled out the switch from the dashboard and disconnected the cable and checked connections in switch, which they were all clean and no sign of burnt. Also checked the cabling and no sign of any issues. Placed the cable back into the switch.
3b. Cleared 01800 error and rerun test on VAG.com, no more errors appeared, so I think maybe one of the connections where not making a solid connection from cable to switch pins.
So basically he unplugged then reconnected it finally cancelled the DTCS an no more problem!
Offline Georrge
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,93533.msg937034.html#msg937034
« Reply #66 on: November 01, 2014, 11:29:54 pm »
Does anyone know how to fit the fuel cap switch?
Instagram @george_kersh
Offline StephenED30
  • -Receive: 53
  • Edition 40 No 135
« Reply #67 on: November 02, 2014, 04:04:28 pm »
See reply No 6
http://www.mk5golfgti.co.uk/forum/index.php/topic,1800.0.html
I think it can be done by undoing the screws on the door card and you can reach up behind if your carful.   :happy2:
Offline Georrge
« Reply #68 on: November 02, 2014, 04:09:04 pm »
Cheers Stephen, ill give that a read!
Literally 10 seconds ago I just fitted the driver side windows and mirror switch, as well as the door pull handle. Looks great!
Quick question though, on the old mirror switch to have the heat function on you have the switch in the middle. On the new mk6 switch, the middle appears to be a '0'indicating off, and the heat function is at the top, and the switch actually pivots 180 degrees to get there. Will the off position still be the heat function?
Offline sootpig
« Reply #69 on: November 02, 2014, 06:04:12 pm »
Heat function will work OK  Mine does   As StephenED30 said  Undo screws on bottom of door card and reach up inside. Small hands and thin blade  :happy2:  On the other hand removing the card is no biggy :happy2:
Offline Georrge
« Reply #70 on: November 02, 2014, 07:40:09 pm »
Do I switch it to the 'O' position to turn it on?
Cheers I'll just remove the door card I think  :laugh:
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #71 on: November 04, 2014, 12:37:12 pm »
Just use the new button like its marks indicate. My mk5 Golf has the same marks as the mk6. Your model is just a bit older. All should work fine. :wink:
Offline Georrge
« Reply #72 on: November 04, 2014, 04:19:29 pm »
I'll just have to test it :smiley:
Just got the fuel switch left to fit now, but it's raining so can't do it at the moment :scared: I'm so impressed with how much of a difference it makes though!
