Author Topic: Window grinding noise  (Read 7861 times)
Nasir
« on: August 13, 2010, 06:46:45 pm »
Hello guys, I've got an annoying problem. The drivers side window was squeaking for a few months and a couple of days ago it gave up. Now every time I use the switch I get a grinding noise. The window drops by itself when driving by a couple of inches. One of the techs at work said it's either gone off the rails or the regulators gone. Any ideas? :happy2:
Nasir
Re: Window grinding noise
« Reply #1 on: August 14, 2010, 11:31:14 am »
Bump
Offline stuupnorth
    • stuupnorth
« Reply #2 on: August 14, 2010, 05:08:03 pm »
hi mate
my drivers window made the same sort of noises
it turned out to be the window regulator was knackered
swapped it and no prob's since
hope this helped
Stu
Nasir
« Reply #3 on: August 14, 2010, 05:36:15 pm »
Thanks Stu, how much was the window regulator? Did you change it yourself?
Nasir
« Reply #4 on: August 14, 2010, 11:48:05 pm »
The misses Touran one did it and I bought the complete plate with all the cables regulator pulleys already built.
Its a mess once it does it and it will take a strip down to see what it is but it sounds like the same.
Have a look on ebay as you can buy an upgrade kit for the Touran so maybe for mk5 too.
Thanks H4RDY, I'm going to take it to my local VW specialist and let them do it.
Offline mortygttdi
  • -Receive: 146
« Reply #5 on: August 14, 2010, 11:50:32 pm »
Nasir if you need a spare regulator or door motor I have both sitting hear you can have them if needed?
No cost
Darren
Nasir
« Reply #6 on: August 15, 2010, 12:35:22 am »
Cheers Darren, I might have to take you up on that offer  :smiley:
Depends what it is though but I'm pretty sure when you scanned my car last time there was some window fault and now it just doesn't work and makes a grinding noise.
Offline stuupnorth
    • stuupnorth
« Reply #7 on: August 15, 2010, 12:29:58 pm »
hi mate
I think I payed £80ish
i think the part no. is 1K3837462A
(drivers side)
and yeah i changed it myself it isn't that bad really it sounds worse than it is
if you want to talk through it drop me a line
01651 843152
hope this helps
Stu
Nasir
« Reply #8 on: August 15, 2010, 12:53:04 pm »
Thanks Stu, do you know if it's different on 3 doors and 5 doors? I might have to ring you if it gets too complicated  :signLOL:
Offline stuupnorth
    • stuupnorth
« Reply #9 on: August 15, 2010, 01:22:16 pm »
Hi mate
not too sure about the difference in the 3-5 door
best check the dealer
I tried most places to get the regulator but no joy
so ended up going to the dealer anyway
Stu
Nasir
« Reply #10 on: August 27, 2010, 11:13:12 am »
Ok, I need some more help on this. The specialist garage have quoted me around £150 which I think is a bit steep. He said you have to take all the window off, the ECUs etc. Is that true?
Offline stuupnorth
    • stuupnorth
« Reply #11 on: August 27, 2010, 08:48:01 pm »
hi mate
I did mine in about 30-45 mins
not sure what the garage is taking about
i'll be honest it takes abit of nerve to take off the outer skin of you door but
once you do it it's not that bad
feel free to call me if you want a nattre about it
01651 843152
cheers
Stu
Nasir
« Reply #12 on: August 27, 2010, 11:22:12 pm »
Cheers Stu, will probably ring you tomorrow at 2 ish :happy2:.
Offline stuupnorth
    • stuupnorth
« Reply #13 on: August 28, 2010, 10:29:55 am »
no worries
i'll be cleaning the motor LOL!!
Nasir
« Reply #14 on: August 28, 2010, 03:09:44 pm »
Hi Stu, I'm probably going to have to give it to a garage to do, just tried take the door card off and sort of broke the mirror switch. I'll be looking to neogtiate on £150 though. Thanks anyway mate :happy2:
